Old 11-16-2013, 05:53 PM   #1
Rodents
HELP! Starting problems, Electrical? Any Ideas?
So my truck has been starting just fine.
Then yesterday I get in it turn the key, the starter engages and after a couple of seconds of trying to turn the motor over it just stops.
Now when I turn the key I get nothing?
No click of the starter/solenoid just silence?
All other electrical seems fine (all lights are working, etc...)
I tried bridging the contacts on the starter solenoid to directly turn the starter over but nothing happened, just a couple of sparks.
Details:
1961 c-10 stock 235 inline 6 with alternator update
Any Ideas?
Thanks!!!!
Rodents is offline   Reply With Quote
Old 11-16-2013, 06:06 PM   #2
kingchr
Re: HELP! Starting problems, Electrical? Any Ideas?
Sorry you are having trouble. First I would start by removing and cleaning both ends of the starter cable. Then make sure that you get the nut on the starter end tight (but not too tight as you can break the solenoid). Only after you finish under the truck should you re-connect the cleaned battery end of the cable. If none of this helps, I would get your battery load tested.
Hope this is useful,
Christopher
kingchr is offline   Reply With Quote
Old 11-16-2013, 06:37 PM   #3
KJSR
KJSR's Avatar
Check your grounds.
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 11-16-2013, 08:00 PM   #4
Rodents
Thanks for the replies
I got it working again
Not exactly sure what the problem was, maybe a loose wire or something.
I just took all the wires off the solenoid (They all looked pretty clean) then put them all back tightened everything down good and she started right up!
Crisis avoided.
Old 11-16-2013, 08:44 PM   #5
TJ's Chevy
TJ's Chevy's Avatar
I had the same issue with mine....I would turn the key and get nothing...so what I did was I tapped the starter with a hammer and it cranked and fired right up....normally if the starter is old or if you connections are old or loose you'll have easy fix problems like these once-in-awhile. Glad your back on the road!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
