Old 11-16-2013, 08:58 PM   #1
pwdcougar
pwdcougar's Avatar
68 side marker light bulbs
What is the number bulb do I use on the side marker lights on a 68? Looks like the number on the one remaining bulb is 189?
My local autoparts store cant look up anything this old.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 11-16-2013, 11:36 PM   #2
vectorit
What?
vectorit's Avatar
Re: 68 side marker light bulbs
1968 truck side markers were not lighted.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 11-16-2013, 11:53 PM   #3
pwdcougar
pwdcougar's Avatar
Strange. There is a a wiring harness and bulb sockets in all four corners.
Paul
Old 11-17-2013, 12:02 AM   #4
pwdcougar
pwdcougar's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1384660918
Old 11-17-2013, 06:04 PM   #5
briank
Mine are lighted as well (1968 gmc burb) I cant get my bulb part out though to read it. I tried looking in the owners manual but didnt see a 189 just a 1895. If I get more time later on ill pull the other side marker off and see if I can get the bulb out.
briank is offline   Reply With Quote
Old 11-17-2013, 06:23 PM   #6
463
463's Avatar
168 or 194 is what should fit
Trueman
463 is offline   Reply With Quote
Old 11-17-2013, 10:25 PM   #7
pwdcougar
pwdcougar's Avatar
The 5 must be the missing digit on the bulb I took out making it 1895. A closer look at the wiring shows that the front marker lights were added rather crudely but the rears look like an additional harness was added to jump from the tail lights to the markers.
Not sure I'll put them back in. The rear marker light lenses were melted from the heat of the bulb. Maybe I'll use part of the 70 harness when I swap bodies.
Thanks for pulling the bulb out of your Suburban.
Paul
