11-17-2013, 07:19 PM | #1 |
Quad carb on my 350
Ok I have a 50 qjet carb on my 350 and want to change for something a bit smaller
Like a 600 etc now what do I look for do I need an electric choke I can't find any wire to my carb re this and I know it's not a manual choke so what do I eed to get to ensure I et the correct sort lie a Holley etc ? |
11-17-2013, 07:20 PM | #2 |
Re: Quad carb on my 350
I'm sure mine is not an electric choke is it a vacuum choke I'm sort of unsure about this
11-17-2013, 07:29 PM | #3 |
Master Hater
type in english and get back to us, I have no idea wtf you are asking
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
11-17-2013, 07:56 PM | #4 |
Sorry it's this iPad
Ok will try again I have on my 350 a 750 quadrajet carb I want to change it for a lower cfm I have seen 600 cfm holley carbs for decent prices but not sure what I need does the standard qjet have a vacuum choke? As I can't see any wire for electric choke and I know it's not a manual so what sort of carb do I need ? Any help will be great |
11-17-2013, 07:57 PM | #5 |
Hope that's clearer still getting use to the text on this thing lol
11-17-2013, 07:59 PM | #6 |
First off, what have you got now? don't know post a pic.
What are you trying to do? and why? IMO, you want a smaller carb, for whatever reason. Keep your foot out of it. Q-jet will run as a 2 bbl as long as you don't open the secondaries. Hey look, cheap and easy. Ok, you posted while I was typing. Q-jet does not have a vacuum choke. Electric, divorced, or hot-air chokes. Personally haven't seen a hot air on a square, but who knows whats been changed over the years. BTW, setups are different from my '73 to '86, what you got?
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. Last edited by donut; 11-17-2013 at 08:05 PM. |
11-17-2013, 08:11 PM | #7 |
The motor is an 86 350 if I do want to go the Holley setup do I get a manual choke? Just trying to get a better setup out of it
11-17-2013, 10:12 PM | #8 |
If your heart is set on a Holley, get an electric choke, you just have to wire it with a keyed hot to operate the choke. Personally I would keep the Q-Jet if you are after economy, the Holley will disappoint you for economy, in my opinion.
Sean "If your gonna be dumb, you gotta be tough" 1960 Chevy Impala Sedan - my 25 year search is over!! 1969 C-10 longbed - Nice day DD 1970 Chevy Nova - Street and Strip Project 2002 Acura MDX my DD 2007 Honda Odssey - My Wife's "Mommy Van" |
11-17-2013, 10:28 PM | #9 |
The Holley will dissapoint across the board unless you've built a motor the Q jet won't feed. A Q jet in halfway decent tune will give better economy, sharper response, and keep its tune better than any Holley. A Q jet is a 2bbl fuel sipping miser until you get into it and the huge secondaries start gulping air and dumping gas. Best of both IMO.
11-17-2013, 10:34 PM | #10 |
Ok would a 600 cfm q jet give me better economy? I'm using it as a work truck so not to worried about speed etc
11-17-2013, 10:41 PM | #11 |
Not measurably. The beauty of the Qjet is that its only as big as it needs to be. I don't think you'll get a noticeable mileage improvement with any carb swap. Tune the one you have, set the timing right, make sure its running tip top and you'll be as good as it can get.
11-18-2013, 12:06 AM | #12 |
There's only 2 sizes of quads. 750 cfm and 850 cfm. No matter what other carb you use you won't find one with smaller primaries than a quad. Unless you find a carter 400 or a WCFB.
11-18-2013, 10:38 AM | #13 |
78K & 79C Jimmys
If your choke pull off isn't working right it can use a lot of gas
tie it off and see how it behaves,in FLA? how bad could it get lol don't go square bore it won't bolt up to a stock intake I have a older Holley square bore now, and I plan on switching back to a stock carb, manual choke
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
11-18-2013, 10:42 AM | #14 |
Ok thanks all so I guess my next question then is.
Is there a good guide for tuning out there somewhere that is the best to use? |
