68 C10 SWB
15x8 5x5 Rallys
Needing some help guys. Looking at picking up Wheel Vintiques 37 15x8 5x5 w/a 4" backspacing for the front and 15x10 w/a 5" backspacing for the rear. I'd like to run spider style lug covers as well. The truck has 5 lug disc conversion from Early Classic on the front and a 5 lug rear end from a 72 on the rear w/drums.
Truck also has a 4/6 drop from ECE. Wanting to know if these wheels will fit my truck, and if I can run spider lug/hub covers. Please halp ![]()
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman |
68 C10 SWB
Re: 15x8 5x5 Rallys
Here are the 10"
http://www.summitracing.com/parts/wv...0505/overview/ Here are the 8" http://www.summitracing.com/parts/wv...0504/overview/
![]() Join Date: Oct 2013
Re: 15x8 5x5 Rallys
a lot depends on what size tire that you are planning to run. did you do the rearend swap? if so, did you get the outside measurements to know how much wider the '72 is. have chrome version of ones you are planning to run on my lowered '68 C10.search here for info here, and elsewhere, on how properly measure clearances on your truck and find out tire height/width
68 C10 SWB
Re: 15x8 5x5 Rallys
Probably a 255 70 15 front and 275 70 15 rear...
![]() Join Date: Aug 2008
Re: 15x8 5x5 Rallys
I running stock 15x8 rallys with 275 60 15, not sure of backspacing
68 C10 SWB
Re: 15x8 5x5 Rallys
no such thing as stock rallys on anything before 73 I believe...
Re: 15x8 5x5 Rallys
68 C10 SWB
Re: 15x8 5x5 Rallys
gotcha
Re: 15x8 5x5 Rallys
If you want to figure out what fits, here's a link.
http://www.carcraft.com/techarticles...t/viewall.html |
Re: 15x8 5x5 Rallys
Re: 15x8 5x5 Rallys
Got a question? I thought that those were the car Rallys .
am I right or wrong? |
#12 | |
Re: 15x8 5x5 Rallys
http://www.summitracing.com/int/part...0504/overview/ |
#13 |
68 C10 SWB
Re: 15x8 5x5 Rallys
What? They are truck wheels... Says so right in the name.
Wheel Vintiques 37 Series Silver 1971 & Up Pickup Rallye Silver Wheels Additional Information Get the right wheel for your vintage GM truck from Wheel Vintiques. Perfect for everything from everyday street drivers to full-blown restorations, these wheels are sure to make your truck stand out from the crowd. Made from steel, these durable wheels feature an OEM-style silver finish, and precise machining so all of your factory accessories will fit.
#14 |
Re: 15x8 5x5 Rallys
Yup it does but it doesn't say OE (original equipment) style wheels like these series 42's.
#15 | |
68 C10 SWB
Re: 15x8 5x5 Rallys
#16 |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: 15x8 5x5 Rallys
With those tire sizes and back spacing you should have plenty of clearance...I have 8" rally's with 275/60/15's front and rear...The rally's I have are 4-1/2" back spacing and rubbed the front fenders in turns and bumps with the 4-1/2" drop up front so I raised it an inch...No more rubbing...I installed a front sway bar as well. Plenty of clearance out back. I used 2-1/2" drop spindles with 2" drop springs up front and the 60's wouldnt clear so reinstalled the factory coils with 1/2 coil cut off...The factory coils are a bit stiffer than the drop coils which is a plus in the turns...IMO
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
#17 |
68 C10 SWB
Re: 15x8 5x5 Rallys
I think I'm going to revise this. Now thinking same wheel 7" wide powder coated back. For tires running cooper trendsetter es narrow white walls in 235/75/15. Plus the spider chrome lug covers.
"How much physical pain do you go through on a daily basis that you can directly attribute to your lack of intelligence?" -R0bman Last edited by marcsRX; 11-18-2013 at 04:02 AM. |
#18 |
Re: 15x8 5x5 Rallys
whatever you decide on run taller tires in the rear - looks much better.
#19 | |
Re: 15x8 5x5 Rallys
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
#20 | |
Re: 15x8 5x5 Rallys
K
#21 | |
Re: 15x8 5x5 Rallys
These are Corvette (style) rally wheels: ![]() Available on Corvette, Chevelle, Nova, Camaro, Corvair, Impala and probably some others I'm forgetting. Production wheels had bumps in the spider to retain the various center caps. Sizes range from 14x6 to 15x8, depending on application. These are truck wheels, first available in 1975 and through the end of the C/K/R/V product cycle. 15x7 for vans, 15x8 for pickup and utility. ![]() K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 11-18-2013 at 02:02 PM. |
#22 |
Re: 15x8 5x5 Rallys
#23 | |
Re: 15x8 5x5 Rallys
"Zero offset" would be in the middle of the wheel, by definition. I'll do some measuring when I get home. K
#24 |
Re: 15x8 5x5 Rallys
Typical wheels are called say 8" wide which is the measurement from bead to bead. However the actual width is 9" which is width from wheel lip to wheel lip. BS is measured from wheel lip to mounting surface.
It would be nice if bs was measured from bead to mounting surface but it's difficult to measure accurately. So an 8" wheel is actually 9" wide minus the bs of 4" leaves 5". Centreline of wheel is 4.5 inches. 5"-4.5" equals 1/2 inch of offset. This link might help. http://www.rimsntires.com/specs.jsp |
#25 | |
Re: 15x8 5x5 Rallys
I have both truck wheels and Corvette wheels readily available. I can do some measuring (once the power comes back on...). K
