Alternative parking brake set up?
Im trying to switch to a frame mount booster and it would be in the way, just curious what options are out there for this. thanks
Re: Alternative parking brake set up?
heres my concern... first pic is the set up and the second two are of my truck. I know that the exhaust is also going to be an issue as well
![]() Join Date: Apr 2008
I think someone makes a parking brake that goes on the driveshaft at the rear diff but I don't know who.
Old member
They also make one that goes under the dash of these trucks also.
![]() ![]() http://www.scottshotrods.com/UnderDashPedalAssembly.asp
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#5 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=296620 about halfway down the first page you can see what i mean The OP did not follow up with the finished install so im not sure what he ended up doing with the booster. Last edited by Drewski23; 11-18-2013 at 06:12 PM. |
![]() Join Date: Mar 2012
i am scratching my head here as to why under the bottom of the cab , checking the fluid is going to be a pain, and more corrosion under there
i could see that set up for a old street rod or a sunday driver.... but not a truck /daily driver
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Different strokes for different folks i guess. Its not difficult for me to get under the cab..maybe for some folks it is. The space and clutter it frees up on the firewall is the main reason for my decision.
my ole fleetline is setup that way from factory. but I have a 4" rubber plug that pops out to check and refill master cylinder.
1964 BBC 402 4x4 ![]() ![]() ![]() ![]() |
#9 | |
http://www.abspowerbrake.com/maincat...ameset009.html |
You can get a floor mounted emergency brake and mount it close under the seat.
http://www.lokar.com/product-pgs/eme...handbrake.html |
