Old 11-18-2013, 03:22 PM   #1
aotte1
292 I6 Engine Roll Around Engine Cradle ?
Looking for source / example of 292 I6 engine roll around cradle/stand. Used for storage of engine and has casters for rolling engine around. See them all over for SBC's. In past have made cradle out of 2x10s in shape where oil pan rail rests on top of rectangle made from 2x10s w/ dip stick , etc. notched in top of boards.
Would add two additional end boards boards that extended beyond triangle for strength and stability. Works however really like the roll around ones.
How is everybody storing their 292s??
Les
aotte1 is offline   Reply With Quote
Old 11-18-2013, 04:27 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 I6 Engine Roll Around Engine Cradle ?
I store mine in the engine bay......HAHAHAHAHHAHAHAHHAHAHHAHAHAHH!!!!!!!!!!!!!!!!!!!!!!!!!!! Just giving you a hard time now!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-18-2013, 07:33 PM   #3
aotte1
I set myself up for that one, hope to do the same once gone through.
Picking new to me engine up tomorrow. It is a 1965, 292 /4 speed trans/ parking brake assembly with low mileage out of an Air Force ambulance. It still has green paint.
Les
Old 11-18-2013, 07:37 PM   #4
paintman
Tom Lowe sells them over on 12bolt.com I have one for my 292 depending on the oil pan you have.... you may not be able to use the center brace. Mine worked just fine without it.
paintman is offline   Reply With Quote
Old 11-18-2013, 10:10 PM   #5
luvbowties
luvbowties's Avatar
Question Re: 292 I6 Engine Roll Around Engine Cradle ?
Les
Can u not use your own idea & just add inexpensive casters from Harbor Frt? Remember u only need 2 that swivel.
Sam
luvbowties is offline   Reply With Quote
