Old 11-18-2013, 04:56 PM   #1
68Stepbed
68Stepbed's Avatar
rebuilding calipers
Has anyone rebuilt, well disassembled and replaced the o-ring and dust boot on stock calipers? I recently picked up a rear disc setup from an old Caddy. Everything is a little rusty but in good shape. I figured I would try to tackle rebuilding the calipers to save some cash. Also, I may look into replacing these with the Wilwood D52 calipers in the future, so I don't want to spend much on rebuilt calipers.
I remembered an episode of MuscleCar on Powerblock where they showed how to rebuild them, so I looked it up. This all seems simple enough, but of course, it all does with some TV magic. The caliper rebuild starts at around the 11:00 min mark.
http://www.powerblocktv.com/episodes.../big-bad-dodge
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 11-18-2013, 05:59 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: rebuilding calipers
I've done a lot of them. Get everything clean, lube the seals with brake fluid when assembling.
