Old 11-18-2013, 07:09 PM   #1
kevinr1970
Spring/ride height, 454 vs. 350
I have an '85 K20 Suburban (350) that has front springs that were bought new 10-15 years ago, but were only driven less than 15k miles.
Measuring against my '91 V3500 Crew (454), the Suburban is just shy of 2" taller to the edge of the fender well than the Crew.
How much of this is the 454 vs. the 350?
The spring packs are the same amount of leafs (3?) and both have negative arch.
I would like to put the Suburban springs on the Crew to help level it out a little bit, but if it is all in the weight of the engine, might be better to just buy some lift springs?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
