New Gauge Cluster Housing?
I'm getting ready to refurbish my gauges and the last time I was in there the cluster tabs/mounting points were getting brittle. I know it only takes a couple of screws to hold it in place but I don't want to put it back together that way. Does anyone make a replacement cluster housing I can swap my gauges over to? This is a factory tach truck, or i'd probably scrounge the yards for a decent cluster to swap parts into. Thank you!
Re: New Gauge Cluster Housing?
Look at lmctruck page 116 and 118.
Grabbed my LMC catalog to see if I overlooked something. Looking at Pages 116-118 and still not seeing the part I need. I see on page 118 part number 38-8100 (10) Cluster Backing Plate. It describes this for an 83-88 cab w/o Tach. Am I stuck cutting one of these up to work with my factory tach? Or, maybe I'm just not seeing the part I need.
I think finding one with factory Rach in junkyard is going to be pretty tough. Heck, if you do find one and it has a tach I'll take it off your hands!
You can repair yours with some fiberglass mesh (like boat repair stuff). Just glob it on and then sand down the excess......
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
While you have it out, hit the inside with chrome spray paint and it will help reflect the light better for your gauges. It helped significantly for me....
#6 | |
I repaired mine with a soldering iron and another crap bezel. Pretty much plastic welding. Link is in my sig
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
I've also used a dremel and some plastic weld epoxy to repair broken off tabs-just as good if not a bit better than plastic soldering. Yep....use a plain jainer cluster for the donor tabs! Lol LMC ain't gonna offer them until they one day exhaust their supply or reg. ones.....once they offer a tach housing.....who'd ever order a non tach one? Lol
I have found that a bit of Vaseline on every screw used in the cluster assembly reduces friction and causes fewer cracked posts. And make the screws up so they are just barely snug - never had one back out.
#11 | |
