Seats for my truck C10 69
Hi folks:
I have separate seats on my truck but sometimes on my breaks I need to sleep but very unconfortable so I want to go back one piece seat. I'd like to see the what you have in your trucks and what vehicles were the donors. Thank you. |
Re: Seats for my truck C10 69
I think that most guys here who have bench seats are using the originals, or at least ones out of similar Chevy pickups
Old member
I used a 60/40 seat out of a 89-90's Chevy truck.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Andy:
I like your seats, was it a direct bolt in? Or what mods did you have to do?
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
So that's what those are. The 67 I'm purchasing has a similar set up in gray cloth. Not sure if I like them in my truck though. Is that a popular option? I was thinking of going buckets. Thanks
#6 | |
Old member
![]() Quote:
U have to reinforce the bottom of the cab to install them. Well to make them safe anyway. I used heavy washers but would be better to tach some angle under the cab I suppose. I like them and I like the way they sit also. Drove the truck 3200miles back in June on the 2013 Power Tour with no problems. ![]() ![]()
Thank you.
Nice seats , I'll wait for more pictures |
![]() Join Date: Feb 2010
I went with the '04 style buckets with the integrated seat belts in my '67. I'm right at 6' and around 225lbs (depending on which bbq place I'm coming back from) and these are a bit too close to the firewall. They're comfortable and fit nicely, but I'll probably try to find an original bench seat or try the second row seat from a Suburban/Tahoe.
-- '67 Chevy Stepside 250 Inline 6 Megasquirt Fuel Injection T5 5 speed conversion Ferric Oxide impregnation throughout |
