Old 11-19-2013, 05:21 PM   #1
OLDGREY
OLDGREY's Avatar
Body mounts or rust repair?
I have been a registered user for about a year. I finally decided to help support the cause. This forum has certainly helped me head off some issues with the build of my 72' Jimmy. The question I have for the members is this. I have plenty of rust repair to do. All the typical areas. I also need to do the body mounts. Should one be done before the other or all at once? Your advice is greatly appreciated. Thanks!
OLDGREY is offline   Reply With Quote
Old 11-19-2013, 05:23 PM   #2
turp mcspray
turp mcspray's Avatar
Re: Body mounts or rust repair?
Fresh mounts first.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-19-2013, 05:27 PM   #3
cleszkie
cleszkie's Avatar
X2 on the mounts. You want the body sitting properly on the frame before you start fixing/adjusting panels.
cleszkie is offline   Reply With Quote
Old 11-19-2013, 07:43 PM   #4
DANTES JIMMY
DANTES JIMMY's Avatar
X3 totally on body mounts no questions
DANTES JIMMY is offline   Reply With Quote
Old 11-20-2013, 10:08 AM   #5
OLDGREY
OLDGREY's Avatar
I was leaning that way. Thanks for the input. I'm sure this has been asked somewhere in the forum. Should the top be on or off when getting the body adjusted on the frame and setting the door and panel gaps? Thanks again!
Old 11-20-2013, 10:38 AM   #6
fxdxharley
Just a nother gear head
fxdxharley's Avatar
Top on. keeps everything lined up.
2013 HD FLHX
2000 chevy 2500 6.0l 4x4 3dr
2000 harley fxdx
71 Jimmy 4x4- future crawler/ woods rig
71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589
fxdxharley is offline   Reply With Quote
Old 11-20-2013, 02:27 PM   #7
mtully79
mtully79's Avatar
^^^ Either that or brace the tub.
mtully79 is offline   Reply With Quote
Old 11-22-2013, 11:17 AM   #8
OLDGREY
OLDGREY's Avatar
Thanks for the advice!
Old Grey-Grandpa's 1969 C-10 SWB in limbo.
1972 GMC Jimmy 4x4, soon to be a driver.
1972 C-10 Custom, daily driver.
Bad decisions make great stories!
