Old 11-19-2013, 05:45 PM   #1
agnes the dog
agnes the dog's Avatar
Front lower fender mounting ?
Does anyone have a pic or two on how the fender should be mounted to the cab on the lower portion? Mine was rigged up by the PO who bent some 1" metal strip to basically hold the lower fender close to the cab. Unfortunately, driving it a lot has caused some distortion of the strip and the fender is now interfering with the door operation. I would like to see how it should be done, because I know it's not correct now. Sorry, don't have pics right now. I'll try to get some up later.
JJ
Just because you can, doesn't necessarily mean you should.
1959 3100 stepside 355 + T5
agnes the dog is offline   Reply With Quote
Old 11-19-2013, 07:54 PM   #2
_Ogre
_Ogre's Avatar
Re: Front lower fender mounting ?
i didn't find any pics of the fender mount; hole in mount, threaded nut in fender is pretty much it.
usually what causes the door fender interference is the front cab mounts getting saturated with oil and collapsing.
you see a lot of stock untouched trucks with doors that are bent with pliers to open the doors
shop air compressor timer
Old 11-19-2013, 09:04 PM   #3
agnes the dog
Ok. Thanks. It recently started to squeak too. Any fixes for that?
Old 11-20-2013, 01:12 AM   #4
kraz88
kraz88's Avatar
Both my doors do the same thing. One fender is just starting to interfere. The other one is so bad I have to kick it to open the door. I think the bolt just totally pulled through the lower mount on mine.
I have no clue how I will fix mine but if you find an easy way let me know!
kraz88 is offline   Reply With Quote
Old 11-20-2013, 10:38 AM   #5
Russell Ashley
Russell Ashley's Avatar
Not sure if this is what you are looking for, but here's how the lower fender mounts to the cab. There's a captive nut (or should be) in the fender that accepts a bolt through the hole in the mount. These brackets are available through most any vendor that sells TF parts.
Russell Ashley is offline   Reply With Quote
Old 11-20-2013, 11:02 AM   #6
_Ogre
_Ogre's Avatar
russell posted the only fastening point for the lower fender.
agnes and kraz both need to change your front cab rubber,
you will only increase the damage to the doors and fender by leaving them
lots of other things that add to the fender interference but usually if your door closes but hits the fender
you can change the cab mounts and fix most of your problems
other items that will cause the door and fender to hit;
hinge pins, rusty floors and cab support around the front mounts, missing rubber on the fender to cab, etc...
Old 11-20-2013, 11:59 AM   #7
agnes the dog
Thanks Russell and Ogre. Russell, is that the passenger side?
Old 11-21-2013, 05:37 PM   #8
Russell Ashley
Yes, that is the passenger side..
Old 11-21-2013, 08:57 PM   #9
1958Warrior
1958Warrior's Avatar
Oger, you described my drivers door , at some time in its life someone took the pliers to it, never had any interference since I've had her. Just wonder what cab mount you referred to , cab to frame or fender to frame rubber as in #12 on the LMC page link?
http://www.lmctruck.com/icatalog/ca/full.aspx?Page=13
Cab to frame all I have is bolt and a few shims up front and rubber mounts on back.
But drivers side hinges have been messaged and tacked welded by PO.Pretty sure that were the damage came from , floors and mounts all solid.
1958Warrior is offline   Reply With Quote
Old 11-22-2013, 12:54 PM   #10
_Ogre
_Ogre's Avatar
kim and orrieg post some good info in a thread a few years back http://67-72chevytrucks.com/vboard/s...d.php?t=439277
item 12 on lmc link is the fender to cab seal, i had to dig around to find the cab mounts on lmc's website
the front rubber is more like shims the back rubber is a thick block
then you have the rubber under the core support, they all deteriorate and cause that fender pinch
the front cab mounts have a tendency to rust out and sag the front of the cab too
Old 11-23-2013, 12:27 AM   #11
kraz88
kraz88's Avatar
Great info. Thanks for the link. I think the cab mount may be the culprit on my driver side. On passenger side the fender has totally come away from the truck on the bottom by the door. Think it rusted out and the bolt ripped through. PO (my grandpa 20 years ago lol) put a sheet metal screw through it but it no longer holds.
