11-19-2013, 07:43 PM | #1 |
How Much Marine Clean
Team:
For those who have used Marine Clean, how much should I buy? I do not want to make two trips, if necessary. Also, did you use it 1:1 or what ratio did you use? Also, how long would you let it sit, prior to washing/rinsing it off? I have quite a bit of build up on the engine side of the chassis and the rear diff. Mahalo!
-JASON My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes. My 1970 C20 Build Thread |
11-19-2013, 07:56 PM | #2 |
Re: How Much Marine Clean
i never used it , i just got a wire wheel and some abrasive discs for the frame and used regular old diesel to degrease, or brake cleaner when i would find it on sale and a good power washer
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
11-19-2013, 07:57 PM | #3 |
also use a putty knife to scrape what you can off first, i know i had 40 years worth of oil and grease on the front crossmemeber under the oil pan
11-19-2013, 08:12 PM | #4 |
Moderator
Marine Clean is the best degreaser you will ever use. Use it full strength and 40 years of built up crap falls off like butter. I don't know the quantity to use, I always have some on hand though.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-19-2013, 08:27 PM | #5 |
Man of Mini-Talents
Who sells it?
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
11-19-2013, 08:44 PM | #6 |
you can get it off of amazon, i think it is made by POR-15
11-19-2013, 10:22 PM | #7 |
Yup, it made by Por 15 and sold at auto paint locations or online. Just like BigMac said.
11-19-2013, 10:25 PM | #8 |
Brake clean works to clean about anything
11-19-2013, 11:59 PM | #9 |
Oven cleaner works great !!
1972 Chevy C10 Custom Deluxe Highlander 1972 Chevy C10 Custom Deluxe Medium Green |
11-20-2013, 05:40 AM | #10 |
i thought it was to expensive to use as a general cleaner/degreaser. I just used it after blasting and before metal prep. I spray to soaking and let it sit 10 minutes before rinsing it and then putting on metal prep.
11-20-2013, 11:06 AM | #11 |
X2. Marine Clean is amazing! Make sure you use rubber gloves though!
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
11-20-2013, 11:38 AM | #12 |
I bought a gallon. I use it full strength in some places, and keep a spray bottle mixed with water for general use. It is a very good degreaser.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
11-20-2013, 12:50 PM | #13 |
I've never used it, but the directions online say mix 1:1 for heavy, 1:5 for moderate, and 1:10 for light cleaning.
http://www.por15.com/MARINE-CLEAN_p_14.html |
11-20-2013, 12:52 PM | #14 |
I love this stuff. I usually mix about 5-1.
