Old 07-14-2003, 10:32 AM   #1
cochino12
It followed me home?
cochino12's Avatar
gear selection help
I am buying new gears and cant decide which to run. I am leaning toward 3:73 but I think 4:10's would help my et's a little more. Is there going to be a noticable diffrence in acceleration between the two? I am running a 700r with 26-1/2 tires. I have done all the calculators and rpm's should be ok with both. Just looking for some opinions before I buy. Thanks
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 07-15-2003, 12:58 AM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Which will give you higher RPMs at the end of the 1/4? Which gear too? I can run the full 1/4 in only two gears at max RPMs with a 26" tire no locking the torque conveter. Do you plan on running a lockup torque converter? If so then the 4.11 would be better. If you run without locking the converter the 3.73 would be better. Higher RPMs and better street gears.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
