Old 07-14-2003, 11:14 AM   #1
speesh
speesh's Avatar
ratzen fratzen brakes!
I have a 71 c10 burb, with power brakes. I have replaced the master cylinder. The brake light comes on if I push on the brakes hard but if I use them gently it doesnt. When I am pushing on the pedal, it feels like it is working, but if I give a little more pressure it goes down about an inch more and the light comes on. The brakes always work though. I bled the brakes this weekend and now it is worse than before! It feels like the brakes are working ok, but maybe not the booster? Can someone tell me how to bleed them correctly? or any other ideas ? I have always had problems with brakes on these trucks, is it just me?
Oh yeah, am I supposed to adjust the rear drums? or is it automatic?
57 suburban(sitting in the driveway), 2 69 C20 longbeds (sitting in the field ) and a 2003 8.1 Suburban
Endeavor to persevere.
"All of a sudden, I'm the old timer!" Some old timer on American Pickers.
speesh is offline   Reply With Quote
Old 07-14-2003, 12:50 PM   #2
Blue4x4
Blue4x4's Avatar
I have found that the Auto bleeder sold at harbor freight works well. You might want to bleed the rears also. The fitting looks like a grease fitting. Good luck
Blue4x4 is offline   Reply With Quote
Old 07-14-2003, 12:51 PM   #3
VTKidder
I've always bled brakes with 2 people; never used a one man bleeder setup. Have someone running the pedal and one on the bleeders. I start at the farthest corner from the booster (passengers rear), then worked up to the front drivers wheel. Have your friend pump the brakes 3 times (engine off), then stand on that damn pedal. Have them holler at you "ON!" or something so you know they're standing on it, then just loosen the bleeder. Fluid comes out (hopefully air too), and when it's done flowing, close the bleeder. Make sure your friend doesn't release the pedal until you've closed the bleeder. Do this to the passengers rear, then drivers rear, then passengers front, then drivers front. MAKE SURE YOU CHECK THE FLUID RESERVIOR LEVEL BEFORE AND AFTER EACH INDIVIDUAL BLEED!! If you're bleeding down low, but suck all the fluid into the master cylinder and start sucking air, you're doing no good at all. Probably making things worse. As far as adjusting drum brakes, it isn't automatic. There should be a threaded setup you can see through the dust cover with teeth on it you turn with screwdriver that pushes the bottom of the shoes further apart (closer to the surface of the drum). Best of luck.
VTKidder is offline   Reply With Quote
Old 07-14-2003, 05:34 PM   #4
Zeus
Zeus
Brake Bleeding
You better double check the bleeding order. I always thought you bleed from the closest to the farthest.
jesusventura@hotmail.com
Zeus is offline   Reply With Quote
Old 07-14-2003, 05:47 PM   #5
68LSS1
68LSS1's Avatar
Farthest to closest is correct.
Edit: Also after bleeding the brakes again and you are sure all the air is out, stand on the brake pedal. If it slowly goes down and then stops before bottoming out you still have air. If it bottoms out then your master cylinder is leaking internally (I've gotten more than one remanufactured mc that is bad out of the box). Make sure you bench bleed them before installing.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 07-14-2003, 05:52 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You should pull your drums and take the adjusters out.You can free the adjusters up then lube them well.They may work for a while but after 20 years of owningm one of these trucks I have never gotten a set of auto adjusters to work for the life of a set of shoes.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-15-2003, 05:25 AM   #7
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Bench bleed?
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 07-15-2003, 07:32 AM   #8
Southpa
Southpa's Avatar
Hmmmm, I had to log in for this one.
If your brake light is coming on I would suspect the proportioning valve is a little off and needs some adjusting. Never done it myself but others here can advise you on that one.
For rear drums I usually adjust them myself. Rear end jacked up, wheels on and tighten the ratchet pawl (little toothed wheel) until you get one full revolution before friction makes it stop. The self adjusters might work if the workings are lubed with "Never-seize" or some other graphite lubricant. But I never trust 'em.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 07-15-2003, 08:14 PM   #9
Blue68
Blue68's Avatar
The prop valve trips when there is an unequal pressure between the front and rear ciruits. Most likely, you have air in one of the circuits, and possibly both. It may also be a bulging hose. As you apply more pressure, it would bulge more where the other circuit won't thus putting more pressure on the sound circuit and pushing the piston in the proportioning valve one way or the other.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 07-16-2003, 12:58 AM   #10
ddsmith
Glowing since 1978
ddsmith's Avatar
Bench bleed?
This means to put fluid in the master cylinder and mount it in a vise or suitable substitute. Run short sections of brake tubing from the master cylinder outlets back up to the reservoirs and push the piston in the force fluid to flow through the outlet ports and into the reservoirs. When the fluid runs air free then the bench bleed is complete. This will ensure air is out of the master cylinder and as long as you don't allow the reservoirs to go empty will rule out this as one of the sources of problem when bleeding the brakes.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 07-16-2003, 02:11 PM   #11
speesh
speesh's Avatar
Thanks, everyone, for all your posts. Now can someone please explain to me how to "adjust the proportioning valve" ? I know it has something to do with the little red button on the end...........
Old 07-17-2003, 12:09 AM   #12
Blue68
Blue68's Avatar
There is no 'adjustment' available. It is either tripped or not. I have heard of resetting when it trips. The circuits require equal pressure on both sides of a valve. If one side drops a piston slides to that side shutting off pressure and triggering the light, which is the switch in the middle, right above the piston. It can be reset by getting the pressure up to snuff on the low side and cracking a bleeder on the high side to push it back. Sometimes, they will 'stick' and require replacement instead of being able to reset.
Old 07-17-2003, 12:22 AM   #13
FrankHoy
FrankHoy's Avatar
You are suppose to be able to set the rear brakes by driving in reverse (10-15 mph) and pressing the brake firmly. You may need to do this a few times. This works, provided the star adjuster is not froze/rusted.
I would suspect your problem is with not being bench bled properly. Follow DDSmith's instructions.
72 Cheyenne 2wd LWB 402/350 CC/PS/PB/AC Tilt/Tach
(upgrading to 4X4 402/700R4 CC/PS/PB/AC Tilt/Tach PW/PL)
71 Custom Deluxe 350/350 Tilt/PS/PB
00 Blazer
FrankHoy is offline   Reply With Quote
Old 07-17-2003, 12:26 AM   #14
my new 72
faster, faster, faster
my new 72's Avatar
I just finished replacing my whole brake system except the prop valve and had to reset it. Here is how I did it. I got a large c-clamp and clamped it onto the prop valve so it held pressure on the pin and allowed the rear lines to flow. I them bled the rears. After the rears were bled I took the clamp off and bled the fronts. After that they work great. they even lock up the big ass 255/55/18 rubbers. Try it and I'm pretty sure your problem will be solved.
I'm going to Law School, wanna debate? It's good practice.
my new 72 is offline   Reply With Quote
