Old 11-20-2013, 12:19 PM   #1
joesgreen67
joesgreen67's Avatar
Good LS tuner around eastern NC area?
Anyone recommend a good tuner for my 5.3?
I'm reading on here that most guys are getting around 20 mpg's....I'm only getting 15.
I got a complete liftout (5.3/4L60e, ECM/TCM, gas pedal, harness) from a 2009 Silverado. Speartech modified my harness and did my programming
Any suggestions on who to see? Around the Raleigh area would be best for me.
joesgreen67 is offline   Reply With Quote
Old 11-20-2013, 05:25 PM   #2
RaceAGMC
RaceAGMC's Avatar
Re: Good LS tuner around eastern NC area?
There's a good place in Mooresville. Depending on how far you are looking to travel. PCM for Less is who did my computer, very nice people and great service.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 11-20-2013, 10:47 PM   #3
Ridgeclimber
I installed a LS 4.8 litre with a 4l60e trani first in my 68 c10. That first use engine was junk. So I then swapped that one out for a LS 6 litre. I purchased the harness, the programmed pcm from http://www.nelsonperformance.com. They first programmed it for the 4.8, then I sent it back to them and reprogrammed it for the 6 litre. They will program it for what ever modifications you have done. They also have an exchange service available. So, no down time. I paid the extra for the performance tune for life. It worked good for me.
Ridgeclimber is offline   Reply With Quote
Old 11-21-2013, 01:32 PM   #4
joesgreen67
I guess they go by "PCM of NC" now. Even though it almost 4 hrs away I'm strongly considering just making the drive. Thank you for the tip.
Old 11-21-2013, 01:37 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
What are the specs on the rest of your mods?Other things besides tuning can have a lot of effect.Tire size,4X4 vs 2wd, can all cause less milage.If it's a 2wd and 3:73 rear gears,you may have it in "Limp Home" mode which will lower efficiency.Certain parts of the ECM need to be disabled to get the best out of one.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
