Old 11-20-2013, 02:54 PM   #1
aotte1
New to me 1965' "292" from Air Force Bus
Just found a 1965, 292 I6 engine from an Air Force flat nosed 22' bus used at "Area 51". Bus showed 38K miles. Air Force used it as an ambulance. I have not had any time to assess the engines condition. It is a little damaged from shipping, carb and dist. Broken. It has a four speed trans w/ hyd clutch. At the back of the trans is an emergency brake as part of the drive shaft.
Initial assessment would indicate that some of the coolant hoses have factory style hose clamps that have not been reused. Color is green w/ torque decal on valve cover. Valve cover is pretty beat up.
More w/ pics coming.
aotte1 is offline   Reply With Quote
Old 11-20-2013, 03:00 PM   #2
1963c-10
1963c-10's Avatar
Re: New to me 1965' "292" from Air Force Bus
Nice find and looking forward to those pics.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 11-20-2013, 03:21 PM   #3
aotte1
I hope here are some pics. More later
Old 11-20-2013, 03:24 PM   #4
aotte1
Another pic. Smart phone not most effocient
Old 11-20-2013, 03:26 PM   #5
aotte1
Another one
Old 11-20-2013, 03:28 PM   #6
aotte1
Starter
Old 11-20-2013, 03:30 PM   #7
aotte1
Valve cover
Old 11-20-2013, 03:33 PM   #8
aotte1
Four speed w/ emergency brake
Old 11-20-2013, 03:37 PM   #9
aotte1
More pics later casting number is 3851659. Have looked for build date yet.
Old 11-20-2013, 03:49 PM   #10
aotte1
I checked it did not have power steering , however, did have "Vac gauge" but was not pulled before recycling. Reportedly because dash hard to get out. It was in storage long time before I got it. However, reported to have been run before pulled.
More/better pics later. My hope is that it is stock inside.
Les
Old 11-20-2013, 10:01 PM   #11
aotte1
For some reason can only upload one image at a time.
Here are a few more pics.
Old 11-20-2013, 10:03 PM   #12
aotte1
Close up of hoses
Old 11-20-2013, 10:05 PM   #13
aotte1
More block numbers
Old 11-20-2013, 10:07 PM   #14
aotte1
More numbers
Old 11-20-2013, 10:13 PM   #15
aotte1
Did quick look in oil filler opening in valve cover and minimum sludge, just very slight amount. So far with quick look is promising. Still hope engine is in good condition.
Anybody recognize the transmission?
Old 11-20-2013, 10:14 PM   #16
aotte1
Numbers on block
Old 11-21-2013, 01:51 AM   #17
Captainfab
60-66 Nut
You can post more than one pic to each post. You just have to upload them 1 at a time from your computer. I'm not sure why, just the way it is since the new server.
I see a newer internally regulated alternator. The trans appears to be a SM420......too bad someone cut the shifter off.
Old 11-21-2013, 08:28 PM   #18
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
Definetly a 292. Nice start...shouldn't be two much to get it going. You can get new plugs, wires, and a distributor cap, and points and a coil at Napa or Auto zone.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-21-2013, 10:13 PM   #19
aotte1
I know on the shifter , said to be long for removal by salvage guy!! And could not get the pin out to remove it. What is this trans used in?
Also thanks for help on ignition parts, I use NAPA a lot too.
Are the engine mounts same for K10?
I sure wish they handled the engine a little more carefully, bent some of the parts like fan.
Where is engine date code on the 292?
Old 11-21-2013, 11:15 PM   #20
aotte1
SM420 trans, could it be the rare 2ton version? The vehicle it came from reportedly weighted 9K lbs. wo/ engine trans when recycled. When have time , have to check the splines. Any advantage for our trucks if two ton unit??
As is obvious I am a novice on this stuff.
Les
Old 11-22-2013, 12:45 AM   #21
Captainfab
60-66 Nut
You do not remove the shifter by removing the pins on the side. You push down on the retainer in the center and twist counter clockwise and it pops out.
Yes the motor mounts are the same for the K series trucks. They are the same for '63-'72 C and K series trucks 10-30.
I believe the suffix code is stamped on a pad near the base of the distributor. Not sure where the date code is on the I6's
I don't know anything about a 'rare' 2 tone version SM420. I do know that the 3/4 ton version has a larger cluster gear shaft. That could also be a year difference thing. Being an advantage or not depends on what you plan to use the trans for. Most guys don't like the SM420 or the SM465 and they pull them out for an auto trans, a car 4 speed, or a 5 speed.
Les
Old 11-22-2013, 10:21 AM   #22
aotte1
Captain thanks for the information. Wish the person I purchased from knew about removing the trans shifter handle.
This is where I read about the two ton version at the following web site:
http://www.novak-adapt.com/knowledge/sm420.htm
Les
Old 11-22-2013, 12:32 PM   #23
TJ's Chevy
Post Whore
TJ's Chevy's Avatar
I far as I know...the mounts were the same. I am not sure. I know the mounts will be in the same location..but I am not sure if the style/height of them is the same.
Old 11-22-2013, 02:41 PM   #24
60-66
60-66's Avatar
I think you will like this engine. Just tuned up my 66 292 K10 Panel truck. If you have mounting questions or need pictures I would be glad to help. Thanks for posting the hose clamp pictures, that will help me in fixing all the mistakes PO made on this truck.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-22-2013, 02:50 PM   #25
60-66
60-66's Avatar
Starter
This picture of the Hydraulic clutch bellhousing in post #6 , you wont need or want it in your K10 but its the same as a 60-62 V8 , The 1960-1962 guys are looking for these as the 60-62 six cylinder hydraulic clutch bell is different where it mounts to the engine.
