Old 11-20-2013, 03:48 PM   #1
jviator
conversion
I want to take a 67'-72' body and put it on my 1980 k20 frame. Or a 73'-74' body. Is that possible? The reason for this is because the state of colorado requires emissions for 75' and newer. Also, can it it be a c20 body or does it have to be a k20 body? The c20 seems to be cheaper.
jviator is offline   Reply With Quote
Old 11-20-2013, 10:55 PM   #2
cst 72 blazer
cst 72 blazer's Avatar
Re: conversion
I don't know about the pickups but there are major body mount diff from my 87 k5 to my 72 k5 but anything can be done and would be cool to see
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 11-20-2013, 11:34 PM   #3
91V3500
Re: conversion
Anything can be done with a big hammer and welder, but the 67-72 is not a direct swap. The 73-74 should be a direct swap, you could just swap the cab from a 73-74 and use the title for the 73-74 and keep the bed and frontend that you have now.
As for the c20 and K20, the only differences that I know of on the bodies are the transmission humps are bigger and removeable on the k20. If you have a 4x4 then you would be better with a k10/20/30 cab.
91V3500 is offline   Reply With Quote
