Old 11-20-2013, 09:47 PM   #1
FLYNAVY30
Engine - Chasis grounds
So where are you guys running chasis grounds for the engine/electrical system? I remember my Z06 used to have one from each side of the motor, and one from each cylinder head. Any input is much appreciated.
FLYNAVY30 is offline   Reply With Quote
Old 11-20-2013, 10:07 PM   #2
Special-Ed
Special-Ed's Avatar
Re: Engine - Chasis grounds
i would do a ground bus
battery to bus
bus to block
bus to chassis
bus to body
bus to radiator core
bus to dash
bus to dash bus for radio/amps
fuel tank to frame
then i would run additional grounds between body panels and additional between frame and body
its kind of like a boat positive bus(fuse panel)
ground bus... every thing grounded back to same ground. this way there is only 1 potential to ground. you will remove 99.9% of all ghosts and gremlins.
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 11-20-2013, 10:24 PM   #3
FLYNAVY30
so heres the next question, which I probably could have answered by opening the box....Ive got a full chasis Painless wiring harness....does that include all necessary grounds, or do I need to add any?
Old 11-20-2013, 10:37 PM   #4
Special-Ed
Special-Ed's Avatar
im unsure... i build my own from scratch as needed.
my guess is no... or limited grounds...
Old 11-21-2013, 10:15 AM   #5
Snailed
Snailed's Avatar
A painless kit won't have any body, battery, or engine grounds.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 11-21-2013, 10:22 AM   #6
Special-Ed
Special-Ed's Avatar
and then people wonder why so many people have electrical gremlins in their vehicles...
they buy a "kit" and dont understand they need grounds... then they have light issues, radio isues, wont run issues, wont stay running under load etc etc....
Old 11-21-2013, 01:54 PM   #7
Angryman117
That is why I build my own. That way I know exactly what I have and know what all of my wires do.
Angryman117's
47 Chevy Build
89 Silverado Z71 LS Swap (sold)
Angryman117 is offline   Reply With Quote
Old 11-21-2013, 09:17 PM   #8
71chevystep4x4
71chevystep4x4's Avatar
Not to mention the hundreds of $$$$$ you save while doing your own
71chevystep4x4 is offline   Reply With Quote
Old 11-21-2013, 09:31 PM   #9
FLYNAVY30
All good points....however, wiring is definitely the weak point in my car restoration knowledge base. So I'm running the painless harness for my carb'd LS swap, but someone please school me as far as what I need for grounds. Like I said, my only knowledge base is troubleshooting my vette which was very susceptible to grounding issues.
Old 11-22-2013, 09:32 AM   #10
Hart_Rod
Hart_Rod's Avatar
battery to bus
bus to block
bus to chassis
bus to body
bus to dash
fuel tank to frame
ground bus... Every thing grounded back to same ground. This way there is only 1 potential to ground. You will remove 99.9% of all ghosts and gremlins.
+1
Hart_Rod is offline   Reply With Quote
