Old 11-21-2013, 02:14 AM   #1
82swb
82swb's Avatar
Need original paint help!
My 64 is missing the trim tag that should be on the drivers side kick panel. Is there any other way I can figure out what the original paint was? Majority of the truck is in primer and some yellow is showing through but I have no idea if it had been re painted sometime during its life. Attached is a picture of the yellow I was talking about and the vin tag. Thanks guys!
82swb is offline   Reply With Quote
Old 11-21-2013, 03:02 AM   #2
oem4me
Re: Need original paint help!
Go around the truck and carefully look for places that may have escaped the primer. Quickie prime jobs often leave trim/bezels in place so orig color may show behind them. Try lifting part of the filler neck gasket enough to see under it.
Old 11-21-2013, 09:08 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
519 GM color code, 549 for two tone, 64-68 Dark Yellow, if it turns out to be original. Same as 62-63 Yuma Yellow.
Old 11-21-2013, 12:15 PM   #4
kieth
kieth's Avatar
Here is a 64 color chip chart
http://www.tcpglobal.com/aclchip.asp...truck-pg01.jpg
just scroll over the chart and the chip will be enlarged, note the other page for interior colors, and tutuone colors.....Kieth
kieth is offline   Reply With Quote
Old 11-21-2013, 05:04 PM   #5
82swb
82swb's Avatar
There is yellow behind filler neck gasket. There is a lot of yellow showing through in a lot of place on the cab. I just wish there was another way to definitively tell me the OG color. Thanks for your help, I was hoping you would chime in
Old 11-21-2013, 05:05 PM   #6
82swb
82swb's Avatar
Thank you, that's helpful!
Old 11-21-2013, 05:06 PM   #7
82swb
82swb's Avatar
Thanks Kieth!
