Old 11-21-2013, 03:09 AM   #1
64chevtruck
check valve quesion
Hi , I have air bags on all 4 wheels of my truck, the air goes from the compressor to the tank, Then to another inline tank, then a line comes out for the front tires, and one for the rear tires, I have 2 dump switches in the dash for front and back,
Can someone tell me where I need to put the check valves in the system please.
Ive looked around and had no luck. Thanks in advance for your time.
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline   Reply With Quote
Old 11-21-2013, 01:48 PM   #2
cg285
Re: check valve quesion
you don't have solenoids on the lines to the bags?
cg285 is offline   Reply With Quote
Old 11-23-2013, 07:31 PM   #3
64chevtruck
Hi and thanks for asking, I have these switches inline between the tank and the bags, Nothing else.
http://www.ebay.com/itm/2-Manual-Pad...6a07f3&vxp=mtr
Old 11-23-2013, 07:55 PM   #4
joedoh
joedoh's Avatar
if you have manual valves, you dont need check valves. check valves are for electric solenoids so that when you lose tank pressure that it keeps backpressure on the solenoid valves. without backpressure, they would equalize pressure between the bag and the tank, and if the tank has zero, so do your bags.
another use for check valves is in line with the compressor outlet where it enters the tank, so tank pressure doesnt load on the compressor piston. usually compressors have them built into the leader hoses, if you have a compressor with a stainless leader hose you probably already have a check valve.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
