Old 11-21-2013, 03:29 PM   #1
jbassC10
Nipple on Master Cyclinder? where to?
Whats the middle nipple go to? lol I know stupid question but all I can assume is it's a vacum line? But where to?
jbassC10 is offline   Reply With Quote
Old 11-21-2013, 03:30 PM   #2
jbassC10
Re: Nipple on Master Cyclinder? where to?
To the left on the bottom I know another line goes in. But the middle nipple hanging out? Vacum?
Old 11-21-2013, 03:33 PM   #3
kwmech
Single wire to a dash lamp when the prop slides to one side or the other in the case of a brake failure
Look for a single black wire dangling under the booster somewhere
Old 11-21-2013, 03:37 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep. That's actually the switch in the proportioning valve, plumbed to the master cylinder and then to the brakes.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-21-2013, 04:20 PM   #5
tony58
Low pressure switch, which is normally open. When the shuttle valve moves due to drop in pressure the valve moves completing ground circuit and the dash light goes on.
tony58 is offline   Reply With Quote
Old 11-21-2013, 06:14 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Should be a brown electrical wire with a rubber boot on it that plugs into it. It goes to the brake warning light in the instrument panel...
LockDoc
Leon
Old 11-21-2013, 09:48 PM   #7
jbassC10
oh Awesome!! Thanks so much!! I'll see what I can do tomorrow finding that wire! I'm pretty sure its still there though! Awesome! Speaking of which this weekend is wiring time! Hopefully will have it turning over and rolling on the 20's!
master cyclinder brakes
