11-21-2013, 07:27 PM | #1 |
What radiator to use in 65 chevy ls swap
I need some help deciding what radiator to use in my 65. I am putting a 5.3 and 4l60e out of a 2000 silverado. Post some pics and ideas.
11-22-2013, 03:07 PM | #2 |
Re: What radiator to use in 65 chevy ls swap
I just used my stock radiator in my '72. A set of 2005 Silverado coolant hoses plumbed right up - except I had to shorten the lower hose about an inch on each end.
Matt Cramer 1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD 4.8 LS build thread |
11-22-2013, 04:10 PM | #3 |
Thanks for the input. My truck did not come with a radiator so I will have to buy one.
11-22-2013, 04:42 PM | #4 |
1965 Chevy C10, 2005 4.8L/4l60
I used a Champion Radiator. works very well and lifetime warranty
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
11-22-2013, 04:53 PM | #5 |
I used an Entropy on my swap in my Jimmy and am happy with it. Here is a link to their 63-66 radiators.
http://www.entropyrad.com/radiators/...ck/cat_25.html
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
11-23-2013, 10:27 AM | #6 |
Hey Clyde65 I was wondering if you had any pics of your radiator. Looks like champion might be a little cheaper.
http://67-72chevytrucks.com/vboard/s...d.php?t=605217 |
11-23-2013, 09:30 PM | #7 |
I'm doing it on the cheap because I can fab things and because I have a pair of Spal fans already. This is the radiator I plan to use:http://www.summitracing.com/parts/gr...make/chevrolet and I might be getting it cheaper now that my work has a wholesale account with A tech which is part of Summit.
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
11-24-2013, 06:25 PM | #8 |
I don't have a picture right now, but it fits in the stock location with the stock mounts, you will need to trim the runmbber just a bit because the champion is more square that a stock one.
11-24-2013, 09:58 PM | #9 |
Thanks for the information. Does yours have a shroud and electric fan?
11-25-2013, 09:06 AM | #10 |
No, I dont have a shroud but I do have two 11" electric fans that came with the radiator. One is on when temp reaches 195 and the other comes on when AC is turned on or it reaches 210. both are pullers.
I found a couple pictures, I hope this helps...
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! Last edited by Clyde65; 11-25-2013 at 09:12 AM. |
11-25-2013, 01:28 PM | #11 |
Thanks clyde65 for the pics looks good. Where did you order it and what are the specs on it? Thanks for all your help.
11-27-2013, 07:39 PM | #12 |
I ordered one off of ebay to fit an 02 vette, it has oil and trans cooler and warrenty for 100$ not a direct fit but easy to fab two brackets out of aluminum strap to hold top two screws hold bottom. And im running a dual fan set off a v6 camaro wich i got for 20 bucks at the salvage along with a coolant overflow tank off a 02 cavileer. My truck idles at 197 on a hot day.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
11-27-2013, 11:27 PM | #13 |
Thanks Robz for the post. I will check into that. Do you have any pics of your install?
11-28-2013, 01:54 AM | #14 |
you can see from the pic that there is two plastic tits on the top that I made simple brackets to hold down and in place. there are two more just like that on the bottom and they are hollow. so I drilled two holes through the bottom of the support and then put 1/2" #8 screws with nuts and lock washers through them that stick up. I just slid the bottom tits over the screws and then locked the top in place. the Camaro fans are the exact size to fit the vette radiator there is like one small plastic piece that needs to be trimmed for them to attach and they are mounted pretty much like gm made them for the radiator. I trimmed the lip off my support so the radiator would sit further forward but only to clear the air cleaner. you may not need that. top hose is a stock truck hose (4.8/5.3/6.0) bottom I will have to look at the # but it is like a 1 1/2 on the pump side and 1 9/32 on the radiator side. these pics are old but I now have my steam hose tee'd in between rad and bottle. and I have a hose from 5/8 wp (heater core outlet) up to bottle back to the 3/4 side of wp(hco). I understand yours is an earlier year model but I bet it could be made to work fairly simple...
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS Last edited by Robznob11; 11-28-2013 at 02:26 AM. |
11-28-2013, 10:18 AM | #15 |
That is a clean install. Thanks again. I am not sure if there is room under the hood of my 65 or not. I am keeping my inner fenders. I will have to measure to make sure there is enough room.
11-28-2013, 02:01 PM | #16 |
well those tits are about an inch tall another way to mount it would be drill 1/2 holes through the bottom that the tits could drop through then cut the top ones off and run a flat c syle clamp to save a few inches. this radiator is a little shorter and about 6-8" narrower than the stocker (67-72) and only about 2" thick. measurements are on the web site. I went this rout so I did not have to run separate coolers or block off to get it running. and if found that the stockers are good enough. with fans installed its probably not much thicker than a stocker. lol ill try and get some more pics for ya
11-28-2013, 02:38 PM | #17 |
What are the outside dimensions on your radiator?
11-28-2013, 04:41 PM | #18 |
I have the cc284 and I ordered from Championradiators.net
My dad has one in his crew cab also
11-28-2013, 04:47 PM | #19 |
Did you get your dual fan setup from champion too?
11-28-2013, 09:39 PM | #20 |
Yes
11-29-2013, 10:33 AM | #21 |
Thanks! On champions website it just had cc284 with a 16 inch radiator.
11-29-2013, 02:37 PM | #22 |
I saw that, I would call them and ask if you could get dual 11" fans.
11-30-2013, 01:19 AM | #23 |
Pro performance is a vendor here and is doing a black Friday sale on champion rads. I just got one for my 68.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
06-11-2014, 12:45 AM | #24 |
Anyone know anything about this? Stumbled on it... but its not searchable thru the site but I forced the part number from TR65's pictures...
http://www.summitracing.com/parts/gri-6-563ar-jax
1966 C10 SWB Fleet 5.3L LM7 Vortec / 4L60e Swap 1966 C10 w/ 5.3L/4L60e Build Thread 2012 GMC Sierra 5.3L 4x4 CCSB |
06-11-2014, 01:17 AM | #25 |
nope, that's brand new.
I used a griffin for a ls-swapped 69 camaro. bolted right in just kidding, it took a 3-4 hours fab works and parts store running. both water outlets are on the pass side so no long hose runs and lots of extra room. |
