Old 11-21-2013, 08:59 PM   #1
rhm63
Problems finding Brake line T
Why is it so hard for me to find a brake line T for my new front lines?
I went to several local places, none had it. Ordered it off of Summit, they sent the wrong part (again).
The line is 1/4 inch with 7/16 thread. From Summit online the part said 7/16", but when I got it, it said 1/4". The compression nut did thread (it wasn't a T they sent). So should I order the part using the line diameter or the thread diameter?
rhm63 is offline   Reply With Quote
Old 11-21-2013, 09:48 PM   #2
64tantruck
64tantruck's Avatar
Re: Problems finding Brake line T
Not sure on yours but our 61 has 3/16 all three ports on ours. Here in NY we cant use compression fitting for brake lines.
Glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 11-21-2013, 11:08 PM   #3
jtrichard
goes by the line/tube od
jtrichard is offline   Reply With Quote
Old 11-22-2013, 01:32 AM   #4
rhm63
Thanks.
Old 11-22-2013, 02:06 AM   #5
suxtobu65
suxtobu65's Avatar
I picked mine up from local hardware store. Stainless t fitting. Also had them in brass.
"Sucks to be you" Suxtobu65
suxtobu65 is offline   Reply With Quote
Old 11-22-2013, 06:25 AM   #6
mark 66
I just bought a brass t with a tab for a bolt mount at napa.
mark 66 is offline   Reply With Quote
