Master Hater
Headers into Single exhaust, lets see your setup
Like the title says I want to go from my headers and y pipe into a single 2 1/2 exhaust exiting behind the rear wheel I found a stock 2 1/2 tailpipe for a 87 3/4 ton, just need some y pipe ideas.
1997 C1500 ECSB 4.3/NV3500 8.5 3.42 "This evening, all of you bleeding hearts... why don't just go ahead and hug yourself for the next 20 minutes or so, because there's a really good chance you're gonna be offended".- Captain Owen Honors |
Cruzzzn' Vet
Re: Headers into Single exhaust, lets see your setup
I had a muffler shop build my 2 into 1 exhaust off the stock Y pipe, from the Y pipe I went 3" single into a 3" Magnaflow cat into a Flow 40 series 3" single inlet to a dual 2.5 outlet muffler dumped in front of the axle, Love it, cruising the parking lots it will set off alarms
![]() This Y pipe from Summit might work for you. |
Master Hater
yea my **** now has a set of **** ass flowcrappers and 2 1/4 dualsa, I'm old and its just too much racket, sounds like a dumptruck with no muffler, I have headers I'd like to keep, just need to quiet my **** down.
Cruzzzn' Vet
Like they say, If it's too loud your too old!!! JK!
Hey i'm 60 yrs young and I love my Flows, Turbo's would be a good choice over the Flows, nice and mellow
Master Hater
yea thats what I'm putting on is a nice 2 1/2 inch thrush turbo muffler, I hate loud exhaust, I like no not draw any more attention than necessary. Also I'm having to build my own cause i can't find a exhaust shop in town that will touch my ****.. guess they don't need money.
#6 | |
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
This is a thread that confuses me. Why would you run headers and then use a 2-1 one system? The point of headers is to create flow from the motor and by going to a 2-1 you hurt that.
If anything you would be better off running a H or X pipe |
#8 | |
Dual 2 1/2" mandrel bent bends into a 3 1/2" single with a Dynomax straight-thru shorty muffler. Driver's side pipe length from the 'Vette Ramhorn manifold exit to the Y-pipe measured 9 1/2" long, used 1 - 4' section of 3 1/2" pipe total. No resrtiction , mostly just a giant collector. We were required to use cast iron manifolds.
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
| Bookmarks |
