Old 11-23-2013, 03:42 PM   #1
CUSTOM/10
CUSTOM/10's Avatar
Air Shut-Off Damper ?
Does anyone have a good picture of the air shut-off damper that goes in the cowl on A/C trucks ? I'm looking for how the spring loaded pin goes into the firewall. There's a hole about 1/2" and the spring loaded pin is about 1/8. I have the plastic piece that goes on the engine bay side, but there must be something that goes on the other side, a bushing or something ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-23-2013, 03:53 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Air Shut-Off Damper ?
I found this picture, and it looks like there is a bushing inside the cowl where the pin goes.
Where can I get one of these ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-23-2013, 05:55 PM   #3
CUSTOM/10
CUSTOM/10's Avatar
This pic has the part I'm looking for circled
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-24-2013, 09:26 AM   #4
CUSTOM/10
CUSTOM/10's Avatar
Anyone ? Anyone have a picture so I could make one ?
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-24-2013, 10:26 AM   #5
budman k20
1972 K20
I think LMC sells that part. If not try one of the many 67-72 vendors or if you're OK with a used used one try the parts board. Even another option is to make one. Pretty simple flanged bushing made from plastic. I had a hard time finding the plastic one on the firewall so I bouight a used one. Good luck!
budman k20 is offline   Reply With Quote
Old 11-24-2013, 10:36 AM   #6
budman k20
1972 K20
I just checked LMC and they do not sell the plastic parts for the AC flapper valve.
Old 11-24-2013, 11:06 AM   #7
Bigdav160
Bigdav160's Avatar
The parts book calls number 4 a BEARING #3895487 and number 3 a CAP #3895486
That's all I got at the moment.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-24-2013, 12:15 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
So far I haven't been able to find one either used or after market. So I guess I'll have to make one ! I'll measure the hole and the spring pin diameters and make one from Teflon or nylon, something like that.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-25-2013, 12:06 PM   #9
48richard
48richard's Avatar
I ended up making one from a nylon bolt from Ace Hardware. Quick and cheap.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 11-27-2013, 12:13 PM   #10
CUSTOM/10
CUSTOM/10's Avatar
Well I tried using a plastic fitting but it broke, so I used a brass fitting and machined the hole over sized and left a shoulder on the inside and inserted a piece of nylon tube as the bearing.
Gary
72 SWB 4x4
My 72 SWB Build
Old 11-27-2013, 12:21 PM   #11
CUSTOM/10
CUSTOM/10's Avatar
One more with the damper installed.
Gary
72 SWB 4x4
My 72 SWB Build
Old 09-25-2024, 11:35 AM   #12
DaHos
DaHos's Avatar
Before I too machine one does anyone know of a source for a correct oem nylon bushing?
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline   Reply With Quote
Old 09-25-2024, 01:21 PM   #13
PbFut
I can not fine any. I need the front one on the firewall. My back one is OK shape, but front is burnt up bad.
PbFut is offline   Reply With Quote
Old 09-26-2024, 11:35 AM   #14
GMCPaul
Sorry to our knowledge neither nylon bushing is reproduced. Anyone with a 3D printer. Brass fitting idea was ingenious in my opinion kudos for thinking outside of the box.
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old 09-26-2024, 12:58 PM   #15
PbFut
Paul
I will have a big order for you pretty soon. Guess I'll have to make one of stock. I don't have access to 3d printer. Thanks for input.
Old 09-26-2024, 03:04 PM   #16
Rust_never_sleeps
Rust_never_sleeps's Avatar
Might check the Hillman drawers at one of the big hw stores or McMaster Carr for a nylon "hat", seems like a common type of uncommon item
1970 C10 Custom longbed 350/350
Rust_never_sleeps is offline   Reply With Quote
Old 09-27-2024, 01:27 AM   #17
Bob B.
Funny there is a nice repop of the damper and the vacuum actuator but no one makes the bushings. My brother made them for me out of Delrin.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 09-27-2024, 03:26 PM   #18
Rust_never_sleeps
Paul Jr @ GMCPauls
IF anyone can post the dimensions, I could print some...once I upgrade my hotend to work with nylon
