GMC Grill InterChange Question ?
I am building a 71 K-10 I picked up this summer, pulled the front clip, cab and bed yesterday. The core support is shot, so I am thinking about converting it to a GMC, will a 68 GMC grill mount onto a 71 GMC core support ? Thanks Guys
71 C-20 07 Magnum RT AWD |
![]() Join Date: Aug 2008
Re: GMC Grill InterChange Question ?
I have never done exactly what you asked but i did do a body off resto on a 71 gmc (my profile pic) and my understanding is all gmc core supports are the same.
Thanks for your input, My concern is with the difference in the 67-68 core and the 69-72 core ? I have a perfect 71 GMC core and a good 68 GMC grill, was planning on marrying the two. I know the early GMC cores are different then the later ones . Any help would be great ! Thanks guys
#4 | |
Captain Obvious says if you have both then go try it! ![]() |
member #16
![]() Join Date: Dec 1999
GMC Pauls has 67-68 and 69-72 supports. The only difference I can think of is the 67-68's have mounting holes for the splash pan, which 69-72;s don't use.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Thanks Guy's I knew about the early splash pan not being used on the later ones, just not sure if the grills are different ? I want to use a 68 painted grill on a 71 core,fenders and hood.
