![]() Join Date: Oct 2012
shoulder belt in 66
Can shoulder belts be put in a 66 chevy truck correctly meaning they would work in a crash? Mine does not have any holes where the shoulder belt would mount. I was thinking about drilling a hole and using a bolt and large washer but not sure. What to you guys think?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Re: shoulder belt in 66
I think their good if you use them for a daily driver. I'm looking at new lap belts right now for my weekend truck. Good thread here in the FAQ's on seat belts. http://67-72chevytrucks.com/vboard/s...=413117&page=2
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
![]() Join Date: Mar 2011
I don't think the shoulder belt would work just bolting it to the sheet metal. It could pull out with the force of an accident without reinforcing in some way.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
What I am wanting to know is can I safely put shoulder belts in my 66?. It has no holes for them now. I know where to buy new seat belts but can this be done safely?. thanks for the replies.
![]() Join Date: Jul 2009
Yes you can. For example, the Juliano's shoulder belts come with a shouldered attachment bolt and a nut that is welded to a 4 inch long piece of steel flat stock which is meant to go behind and serve as reinforcement for the sheet metal cab wall.
![]() Join Date: Mar 2005
For the reinforcement plates, check out what Brad did on his truck:
http://67-72chevytrucks.com/vboard/s...320546&page=13 Check out post# 303. You could easily make these with a piece of flat steel and a nut if you didn't want to buy them.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Thanks guys THAT is what I was looking for. I am thinking about making my 66 a driver and letting my son drive it to school next year but wanted a good 3 point seat belt. It looks like what brad did will work and be safe.
