Old 11-23-2013, 04:57 PM   #1
Straight six
Straight six's Avatar
Front suspension swap
Well I'm looking to redo my front suspension. I have a 78 c15 heavy half ton. Are there any kits that come complete with control arms shocks springs ect that I can just bolt in. I'd rather not change piece by piece if I don't have too.
1978 GMC C15 4.1 250
Twitter: StraightSix78
Instagram: StraightSix78
Straight six is offline   Reply With Quote
Old 11-23-2013, 05:24 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Front suspension swap
Stay away from replacing the control arms. Rebuild your originals. The aftermarket arms that come all assembled are low quality.
Suspension work isn't easy and quick to do. Shop for only the highest quality components so you don't have to redo it in a few years. Assemble your own kit with top of the line brands. It's not hard. You could sit down with the Internet and shop and choose all of your components, order them, and complete the process within an hour. Then its a matter of doing the work when your parts arrive.
Few places consistently offer better prices on quality parts than Rockauto does.
Old 11-23-2013, 06:29 PM   #3
Straight six
Great thanks for the much needed help. Since it's a heavy half can I use standard 1/2 ton parts or 3/4 ton parts?
Old 11-23-2013, 06:48 PM   #4
Tx Firefighter
Front suspension parts will be half ton. Five lug wheels.
Try Rockauto. Click on the interactive catalog and make your way down to your vehicle in the listings. Then look for ball joints, control arm bushings, inner and outer tie rod ends, idler arm, pitman arm, coil springs, and shocks. That will cover your front end rebuild in a "shotgun" manner, that is everything. Pay close attention to any details when your reviewing the parts options. Things like "GVW xxxx" and "with heavy duty susp" are often there to differentiate between similar parts. When I feel sketchy about which part I need, I open a second tab to O Reilly Auto Parts and look up my stuff there too. Then make sure the part numbers match between the two places.
Old 11-23-2013, 06:57 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I beg to disagree with TX firefighter.. Front end work is no harder than any other work on our trucks IF you have the right equipment to do it. On the ground is the hardest way to do any repair but if you can find a lift to work on your truck, it is actually pretty easy and a lot quicker..
I do agree tho Moog parts are probably the best to use Ive never had any problem with those
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 11-23-2013, 08:20 PM   #6
Tx Firefighter
Bob, I've always been hesitant to push folks into digging into suspension work themselves. Like you, it's pretty easy for me also, but I'd say its always been my favorite phase of any truck project. Some folks who aren't familiar with it struggle mightily with getting through the job. For an experienced guy, popping a ball joint loose is a 15 second deal. For a beginner who has never done it, it might take two or three trips to this board, reading, back outside, back in to read, and finally success with getting it separated.
Old 01-16-2014, 03:06 PM   #7
Straight six
I know it was said not to replace my upper and lower control arms because of the low quality or repos but mine are really shot since I'm replacing everything else suspension related I want those done to. Are ones like ac delco or rebestos ok?
Old 01-16-2014, 03:39 PM   #8
cory d
cory d's Avatar
are the control arms themselves toasted or just the bearings? if it was me, i was go with energy suspension polyurethane bushings (i run those on my truck), choose the springs you want from moog (i like the 6454 but trimmed a little) and good, quality ball joints. as for shocks, just choose which ones you like
cory d is offline   Reply With Quote
Old 01-16-2014, 03:49 PM   #9
Straight six
Yea the control arms are shot
Old 01-17-2014, 03:19 AM   #10
cory d
cory d's Avatar
i would find some in a bone yard, just make sure you can do it safely. they dont always allow allot of stuff you may need
Old 01-17-2014, 09:59 AM   #11
Straight six
Unhappy Re: Front suspension swap
Why can't I buy new ones are all of them that horrible? Why would I want to get used ones got to find a place to sand blast them then paint then then press balljoints, bushings. I wouldn't mind doing that but the sell new ones like raybestos, ac delco and dorman so the advice I'm getting is all if those for example are trash and won't work. So go to the bone yard and find some 30 year old parts and refurbish those..... Off to the bone yard here on the east coast to find some rusted gems great...
Old 01-17-2014, 11:44 AM   #12
mrolds88
I believe what they are trying to say is that those new aftermarket control arms are not the quality of the old OEM parts. They may vary dimensionally resulting in ball joints or bushings not fitting, or not being able to get truck aligned properly. Or the quality of the material they are made of. I know up in the NE you guys are handicapped by salt and such. You may have to find some to the south and ship them in. Remember it is safety first.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-17-2014, 12:25 PM   #13
Straight six
Ok I got just so were clear every brand of reproduction control arms are junk and will or might not work because of different dimensions and safety wise they suck.. Well that blows I guess it's not good to buy anything that's not oem think I'm gonna put this project on a hold for now not fun anymore....
Old 01-17-2014, 01:03 PM   #14
bdiamond
Rebuilding your first front end I wouldn't call fun anyway. Character building, vocabulary increasing and a few other things, but not fun. Don't give up so easy... If you need a good set of builder arms I'm sure there is a set for sale on here. I bet if you asked nice one of our members that isn't in the rust belt could hook you up fairly cheaply. Builder arms are all over the place here. Rust free and shipping is cheap....
bdiamond is offline   Reply With Quote
Old 01-17-2014, 01:16 PM   #15
Straight six
Ok thanks. Yea just a little frustrating I know there's some kinda light at the end of the tunnel.
Old 01-17-2014, 02:30 PM   #16
Pyrotechnic
Pyrotechnic's Avatar
Go over to the for sale section of this forum and post a "want to buy" add for a complete set of control arms if yours are rusted out or bent. In the southern states without rust problems, there are probably tons of good OEM control arms on old truck carcasses that get sent to the crusher...just because in most cases we never need to replace them around here. I'm willing to bet you could find someone parting out a truck that could make you a deal on some that they would have otherwise sold for scrap metal.
What exactly is wrong with the ones you have now?
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-17-2014, 03:07 PM   #17
Straight six
Mine are rusted out very bad pitting left lower little bent. I was buying everything else new so I kinda wanted to keep with that but now I know it's either oem or south,west control arms which is I guess is fine if I can find some.. I will definitely post in the want ads to see what I come up with thanks...
Old 01-17-2014, 03:36 PM   #18
SCOTI
SCOTI's Avatar
Porterbuilt sells aftermarkettubular C10 a-arms that can work w/coil springs if you just want better than china-made repop arms. CPP also offers some but I like PB's (better bushing material & better geometry).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2014, 04:49 PM   #19
KrazyRay
KrazyRay's Avatar
Take the advice from Tx Firefighter. I did when I did my 87 GMC and I smile when going down a 2 lane road knowing that my truck isn't going swerve into oncoming traffic. The main tool you need is a ball joint press for the lower ball joints or you can hire a shop to press them in. If you are interested, I have OEM control arms with no rust that I can sell you a set of 4 for $80 plus shipping. Then go get some Moog parts and you should be under $300 for the control arms R and R.
KrazyRay is offline   Reply With Quote
Old 01-18-2014, 03:30 PM   #20
nekkidhillbilly
dont like global west and a few other places make performance control arms? just a thought i know it would cost more but would make a awesome truck.
nekkidhillbilly is offline   Reply With Quote
Old 02-15-2014, 09:21 PM   #21
KrazyRay
KrazyRay's Avatar
Here's the control arms:
Old 02-15-2014, 09:25 PM   #22
Straight six
I'm so excited!!!!!
Old 02-19-2014, 09:48 AM   #23
Straight six
Stupid question?? When I remove old control arms and replace them do I reuse all the shims or not? I have heard when doing all new suspension and steering parts I don't add any shims just start from a clean slate and add as needed..
Old 02-19-2014, 10:29 AM   #24
SCOTI
SCOTI's Avatar
If just swapping parts, I always add the shims back as they were. If changing height while swapping parts, I'll do the same but remove equal amounts of shims from each corner to ballpark the camber settings until proper alignment.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-19-2014, 10:58 AM   #25
Straight six
Great thanks... I'm also lowering the front 4.5 inches so I'll be adding the shims back to their original locations...
