11-23-2013, 06:58 PM | #1 |
1968 K1500 V6 Farmer Green
OK I stumbled upon this old girl about a year ago... a rusty old original that had just arrived at a local yard. Basic Gyppo Strippo Model other and some Farmer Tech and some late model car seats...it seemed to be complete and still turned over. it has an old school Fisher Speed cast plow. VIN KM10D_PB27XXX GVWR 5800
below are pics as I found her. original 305E with a 1960 intake and Holley I bbl
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style Last edited by glimmertwin01; 11-23-2013 at 07:06 PM. Reason: added info |
11-23-2013, 07:03 PM | #2 |
Re: 1968 K1500 V6 Farmer Green
Because I know how you guys in better areas love to see rust pictures.... here ya go
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style |
11-23-2013, 07:12 PM | #3 |
I plan on keeping her a basic truck dark green no chrome.
Maybe one of you will know if the white grille was basic trim level? Ive seen many with a argent grill but few with a white grille... I like it. The cab on this thing is shot.... but all of the interior is there Lt green glove box Inst panel Visors and door panels. the SPID is missing. . It has the 16x6 steel rims with 7.50x16 pizza cutter snow tires. It is a 4 speed too....
11-23-2013, 09:49 PM | #4 |
more updates tomorrow to bring this project up to date.
11-23-2013, 11:36 PM | #5 |
I have a radical idea!
I love V6 trucks!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-24-2013, 09:47 AM | #6 |
Fast forward to late March 2013... after a long winters nap. I spent a day with the old girl... checked all fluids (check) and proceeded to replace the coil, points (set to .017), condenser, Cap, rotor and wires. plugs appeared fine.
Put a battery in her cranker her for 2-3 min with ignition disconnected to get oil in her at low rpms..... connected the ignition, gave her a splash of fresh gas and hooked her to a small can of fresh fuel. set the choke, turned the key.... She roared to life first turn.... she clattered a bit, smokedn shook, after a min or 2 she settled down and ran decent.... ( ive seen videos of 305s running on Utube) she sounded and ran fine.... we then replaced the hood with a red 68 chevy hood. the original one was shot and the passenger side holes for the hinge had long since rotted away. I had to tug on the core support to get the hood to close right. At some point, the truck had a front end hit on the drivers side which punched the eyebrow in and they did a **** job of fixing it. and the core got pushed in . so I was curious to see if she moved.... dropped it in Lo and she moved. Mind you there are no brakes, but the drums offered resistance ... I drove it around the yard a little and parked her in a new spot.
11-24-2013, 09:50 AM | #7 |
Due to the fact the underside of the cab is toast, the linkage and such did not work the smoothest but it ran and most of the lights worked ... even the idiot lights worked.
I was off to find a cab. and since i had 2 other projects to button up. I left her all summer. to sit.
11-24-2013, 09:58 AM | #8 |
Fast forward to Sept. I located a decent cab... not mint but soild in the important areas. its a 71 Chevy 2wd cab. It was Ziebarted so the main floor and month areas are excellent and the area above the windshield is rust free.
the guy tossed in a set of 5 16x6 steelies he had from an old 68 2wd he was trying to fix....and offered up 2 doors... not the best but can be used until i can get my good pass door on and find a drivers door. 250 bux.... the outer floor on the drivers side is the worst.... but i have a new set of outer floors... I need to grab floor supports to fix the outer half, A-pillar drop, kick panel cab corners.... but its very serviceable as it sits....
67/68 K/20 "The BEAST" 68 K15 V6 LWB. 73 K20 GMC Burb "The Bomber" 74 K/5 74 K20 Custom Deluxe 86 K10 Shorty 92 K2500 Burb 95 K2500 GMC Life is what you make it Live each day like it was your last Old GM Trucks never go out of style Last edited by glimmertwin01; 11-24-2013 at 09:59 AM. Reason: spell check |
11-24-2013, 10:05 AM | #9 |
The bed is solid underneath but the sides are shot and in need of a tailgate. I looked on CL, and located a nice solid set of 8 ft GMC bed sides... ( he had just sold the tailgate)
picked em up and was given a very soild passenger inner fender as a bonus. (free is good) the bed sides came with the inner tubs and the lower extensions...
11-24-2013, 10:12 AM | #10 |
Disassembly of the front clip.
I spent 5 hours taking the front fenders off the truck to prepare for the cab removal.... gotta love when people use a nut and bolt on a difficult spot ( Drivers front lower bolt core support to fender behind the marker.. Of course all the inner to outer fender J nuts were rusted junk and broke as soon as they were turned. but I got the clip off... sorry no pics..
11-24-2013, 10:20 AM | #11 |
spent 2 afternoons gutting the cab. the heater box is junk, the mice had a nice home in it and their urine rotted the bottom out of it... the heater core is solid and the coolant is like new..... gas tank was perforated at the bottom probably when the rear supports gave up the ghost. (he was running it on a 5 gallon can on the passenger seat.
here is what it looked like gutted
11-24-2013, 10:29 AM | #12 |
Cab removal.. Removed the cab Friday 11/22.
after it was all gone i surveyed the frame... as i thought... very solid
11-24-2013, 10:33 AM | #13 |
3 of the cab mount ears were semi shot... so I get to cut plate and and replace the tops... so the cab swap didnt get completed (it is dark here at 5 pm this time of year) .... but we moved her up by the shop so i can have electric for the welder....
12-09-2013, 05:16 PM | #14 |
i got the cab mount areas repaired last week (pics to come) and while getting the cab ready to set on the frame, I was poking around the yard and found a slip on rear passenger cab floor support and a set of cab corners, i already had a drivers a pillar extension, a set of rockers, a drivers side complete outer floor (frt to rear) and front cab/ floor supports. i got busy and got the passenger floor support and made a rear outer floor based on the drivers side but reversed and installed them with the cab corner,,
I was working out in 28 degree weather but its butt welded and solid.. and a pic of the drivers side floor to be repaired.
12-10-2013, 12:49 AM | #15 |
Any pictures of the 16" rims that got thrown in with the new cab? Curious roses what they look like
12-10-2013, 01:03 AM | #16 |
Vintage 4x4s
The V6's are neat aren't they? Most 67 GMC's didn't have SPIDS. I wonder if yours ever had one...
The cast plow isn't cast iron is it? Looking forward to seeing the rust repair, need to do that on mine.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
12-10-2013, 08:12 AM | #17 |
the 16's look exactly like the silver one on the right front. except they have 16x6.50's
12-10-2013, 08:18 AM | #18 |
How's the blade for it?
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
12-10-2013, 08:34 AM | #19 |
hahahaa you know I dont have a blade Brett, you call on that 85 last night?
12-10-2013, 08:36 AM | #20 |
No not yet. Saw pics this morning, going to call today after work.
12-10-2013, 08:38 AM | #21 |
cool... Im goin up to finish the drivers side and set her on the frame... snow is coming. and I will be in the heart of lake effect.
12-10-2013, 07:55 PM | #22 |
cold day out in the wilderness. no lake snow but hit a ton when i got home...
as promised... repaired frame cab mounts, and a pic of one of the freebie 16 in truck rims complete with a 6.50x 16 traction tire
12-10-2013, 08:01 PM | #23 |
pics of the outer floor repair and the front cab mount to the repaired A pillar bottom.
12-10-2013, 08:05 PM | #24 |
Awesome old truck! Subscribed!
-j-rod '06 3500 LWB CC 4wd, 8.1 Allison |
12-10-2013, 08:06 PM | #25 |
replaced cab corner but it was so damn cold i had issues with warpage but it is on and all steel.... and the new rocker,,,, damn cold out and didnt get the cab set back on the truck...
