61 3/4 ton limited slip rear differential
61 3/4 ton limited slip rear differential taken out of a 61 chevy truck with 4 10 ratio $275 plus shipping
Re: 61 3/4 ton limited slip rear differential
are you sure they are 410s and not 457s
i would have to double check but i had counted 41 on the ring and 10 on the pinion i will recount and confirm
picures
Any interest in separating the posi unit by itself and not shipping that massive chunk. All im interested in is whats inside the carrier. Thanks.
never got a confirmation on what gears are in there
j kirn it is a 4 10 ratio
obijuan i would be willing to separate if j kirn is mot interested |
I am looking for 457s, thanks
j kirn i also have a 62 with limited slip i will let you know the ratio once i get it out
So what do you want foe the posi?
$150 plus shipping for the posi unit
Ill take it. Please send pics of assembly once removed. To ensure good condition parts. These either work or are blown up lol. Thanks.
#13 |
Bueller....
What would you sell the whole drop out third for? Shipped please. |
#14 |
pics for obijuan
#15 |
i can see it in there. i am needing this assembly inside that carrier.
separate the carrier in half with the ring gear bolts. its inside. |
#16 |
this is what i have once the case is split
#17 |
as long as theres no cracks or missing/broken teeth it ought to be good.
#18 |
i looked it over once more and everything looks to be in good condition
| Bookmarks |
