do hellwigs make my truck feel more rough?? pics inside
Got my truck on the freeway and it bounces in the rear. Its not like a no shock bounce, but like a quick stiff bounce. It rides real smooth till i hit bumps, I know its not a cadillac its a 3/4 ton 85 model. It has a hellwig on the back spring that makes it a 1 Ton..
If I remove it, as i dont need it, will it soften my ride some?? ![]() ![]() |
Re: do hellwigs make my truck feel more rough?? pics inside
the helpers will make it ride rougher what i would do is just undo the front and rear spring ubolts that hold the helper springs and see how it drives .. if you dont notice any difference it wont hurt anything to leave them on
4x4k30 if trouble was money i would have plenty |
#3 | |
i doubt it's even hitting them.. a 3/4 ton will ride like that regardless.. easiest/best put a few hundred pounds out back, it'll ride better.. it'll make the suspension cycle.. not just lift the truck up.
-'73 c/10 - Low with Go - will be complete... probably never. -'90 2wd Blazer - well... soon enough anyways. -'84 SWB - the daily gas guzzler. |
you can move the pads they hit
oh never mind. i just assumed it was the normal helper springs.
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
well i removed the bolts on both ends and low n behold the rear dropped like 3/4 to an inch. the ride is a big time difference. now freeways drive are comfortable and not choppy. city driving is a whole lot smoother also.
And to think I was going to start a thread on how to lever out my truck LMAO... |
Nice! One thing down...
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
It makes sense that it would ride better. The springs can't move all clamped down like that.
![]() 1985 C10 2004 Avalanche |
My '87 rode rougher than crap. It was lifted and was an 1/2 ton longbed. Worst ride ever. It would vibrate your teeth out it rode so bad. It didn't even have helper springs. But you know I put ten batteries, a bumper and some other stuff in the bed plus pulled my '76 with a tow dolly and the truck didn't squat. How I don't miss that ride.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#12 | |
#13 |
old ih 4wd dually my great grandpa had was prob the worse riding thing ive ever been in but you could put 2 tons on the flatbed and it wouldnt squat. it killed you though to drive. it was a early 60s one.
