Old 11-24-2013, 02:56 AM   #1
lml
Rear suspension uneven
I purchased a 71 C10 long bed with 3 in. drop in front and 3 in. drop in rear. All suspension components are fairly new. I like the stance but one side of the rear sits lower than the other. Is this a problem with the rear coil springs or is there an adjustment that I can make? Thanks in advance for any advice or information.
lml is offline   Reply With Quote
Old 11-24-2013, 08:57 AM   #2
cdowns
cdowns's Avatar
Re: Rear suspension uneven
normal on old chevy trucks due to tweaked frame after 40years of hard work 95% have it to some degree
Old 11-24-2013, 05:13 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Welcome to the board.
Can you post any pics?
How well does the bed sit in relationship to the cab?
Keith
Convert to disc brakes.
Old 11-24-2013, 05:57 PM   #4
oldman3
oldman3's Avatar
Welcome to the site. As Keith said pics would be nice. 1st thing I would do is measure from frame to trailing arm on both sides, this should tell you if the springs are the same. 2nd check bed mountings to see if one side might have rusted away. 3rd these long beds were worked hard and the frame could be cracked or bent. I had to repair one that was cracked across the top and 3/4 ways down the side, behind a bracket. Pic1 shows bracket removed, ready to grind out and weld. Pic 2 shows how someone tried to fix with a piece of angle iron. Pass side was a good 1-1/2" lower...Jim
oldman3 is offline   Reply With Quote
Old 11-24-2013, 06:12 PM   #5
lml
Thanks for your replies. I'll check the items you noted and see what I come up with. Thanks again.
