11-24-2013, 12:36 PM | #1 |
Rear axle gear ratio?
The truck is a 1970 c10 short box. The vin code identifies it was a inline six motor. It now has a 350 with turbo 350 trans and currently winds up to 3000 rpms at roughly 60 65 mph.The code on the top side of the passenger tube of the axle says TDA 0226w2 the the front side of the pumpkin says NF3896838 and GM56. The webbing on rear says con1 and 1234567890. Also looking for suggestions on how to remedy this. I assume 700r4 is one option but what other options are there.
11-24-2013, 12:41 PM | #2 |
Re: Rear axle gear ratio?
Get a 3.08 rear end from a similar truck.
11-24-2013, 01:08 PM | #3 |
200r4 works great in place of th350. Crossmember needs to be moved back or mount adjusted. Driveshaft is the same yoke and length. Best part is the .67 overdrive. Fairly simple kits available to take care of lock up convertor.
11-24-2013, 01:17 PM | #4 |
Welcome to the forum Jarrod! Cold up in Sioux Falls yet? I wore shorts this morning to walk the dog. Then again, it's 115 here all summer long... Anyway, you didn't mention tire diameter, and that's kind of important here. So, for the sake of discussion, I'll assume an approx. 28" dia tire. Here are some numbers:
At 60 mph with a TH350 (and 28" dia tire): 4.10 rear = 2952 rpm 3.73 rear = 2686 rpm 3.08 rear = 2218 rpm Wrenchbender is correct, one way to skin the cat is to install a 3.08 rear from another truck. The tradeoff is your ability to do a burnout, if that is important to you - it kinda goes away because you lose a bunch of torque multiplication in all gears with a 3.08. A 700R4 (or better yet, in my opinion, a 2004R) would give you the best of both worlds - a bit more torque multi in 1st, but also an o/d gear for hwy use. At 60 mph with a 700R4 (and 28" dia tire): 4.10 rear = 2066 rpm (but, note, you'll have almost TOO much torque multi in 1st - will want to shift to 2nd before you cross the intersection...) 3.73 rear = 1880 rpm 3.08 rear = 1552 rpm (bad combo, 700R4 and 3.08, unless you're gonna be cruising over 100 mph...) At 60 mph with a 2004R (and 28" dia tire): 4.10 rear = 1978 rpm (same note as above) 3.73 rear = 1799 rpm 3.08 rear = 1486 rpm (same note as above) The factory often pairs a 3.73 with an o/d trans - for good reason, great combo of off the line perf and highway cruising rpm mildness. The other options available are to change tire diameter, but if you like what you've got, then you should keep what you've got. (hmmm...) Or, you could keep the TH350 and install a Gear Vendors over/under drive and use it as a tack-on overdrive. Not cheap, but bulletproof, with approx. the same results as a 700R4 swap (just the o/d gear part, not the low-end toque multiplication). Recommendation: 3.08 if off the line perf not hugely important. If you like acceleration(!), or if you plan to tow/haul anything: 2004R. Hope that helps. And, again, welcome to the forum. Last edited by jocko; 11-24-2013 at 01:22 PM. |
11-24-2013, 01:58 PM | #5 |
70+ ( Old Skool Club )
If your truck was an original automatic it shoukd have a 3:73 final drive ratio with the 6 cylinder engine. From what I've read and heard on this site a 3:73 with a 700r4 trans gives yiu the best of both worlds. The other factor is the cost if the 700r4. You are probably looking at a minimum 2000. to buy and install a 700r4 properly.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
11-24-2013, 07:46 PM | #6 |
I am pretty sure it was a inline 6 with a manual. Not sure the tire hieght but they wheels and tires will be changing soon. Currently has 225 50 17s. And yes todays high was 30 yesterdays was 15. Little chilly thanks for the welcoming.
11-24-2013, 08:32 PM | #7 | |
The Older Generation
According to the charts I posted a while back 1970 TDA would be 3.73:1. I changed the rear in my White '67 from a 3.73 to a 3.08 and it worked like a champ. I also put a 2004r trans in my Suburban and had to go from a 3.08 to a 3.73.... http://67-72chevytrucks.com/vboard/s...d.php?t=578793 Oh, and to the board. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-24-2013 at 08:38 PM. |
12-03-2013, 01:27 PM | #8 |
So with the information I listed its also a non posi rear? thanks again everyone.
12-03-2013, 09:19 PM | #9 | |
It is not a positraction. LockDoc
12-22-2013, 05:01 PM | #10 |
Does any one know with this 1970 c10 2wd 12 bolt tda 373 open differential would it be 30 spline axles? Looking to purchase a mini spool for it.
12-22-2013, 05:52 PM | #11 |
Got my Rallies on with these tires are little taller and its a little easier on Rpms on highway. But i think that the plan will be to swap my turbo 350 for a 700r4 or a 4l60e.
12-22-2013, 06:53 PM | #12 | |
Here is the original 70 powertrain chart, most are at a link in my signature.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 12-23-2013 at 11:59 PM. |
12-22-2013, 09:54 PM | #13 |
Its not a truck thats drive daily just driven ocasionally. Might see a few passes at the track next year not sure. I have been looking for a posi rear end for it but havent had a lot of luck with that. So would my axles be 30 spline?
12-23-2013, 11:45 PM | #14 |
5 or 6 lug is going to be 30 spline from the factory for a 3500lb (HO35) 12-bolt rear end.
If you are having trouble finding a posi axle you could always install a lunch box locker that reuses the existing case. Not the best of solutions but better than running a spool.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-24-2013, 03:10 AM | #15 |
never heard of a lunchbox locker please enlighten me thanks frank69
12-24-2013, 03:41 AM | #16 | |
http://www.ringpinion.com/b2c/Produc...Spartan_Locker
