Your UncleBen
![]() Join Date: Dec 2002
Show your roll cages!
Hey there! Looking for different ideas on cage design for our trucks. Especially interested in how the rear bars go through the window/cab of the truck and tie into the frame. Also how the front bars come through the firewall and tie into the front portion of the frame.
Show off your cage and design. More pics the merrier! thanks CHRIS
68 C10 shortbed -- Street/Strip ![]() |
Re: Show your roll cages!
I've searched and think I've seen every pic on here, but would love to see more! I just got my bender and bend tech program to start my cage.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Which Bend Tech software did you get? If you got BT Pro, you can build your entire cage before you ever cut a piece of tube. It can take a little bit to learn the software, but it is very cool for designing tube fabrications. One of the keys to accurate tube bending with Bend Tech is calibrating your dies correctly.
I just got the Bend Tech EZ, because I don't plan to go crazy on my truck and just putting in a 12pt.
What do you mean by ''calibrating your dies''? The bender I've got said they are on a 5'' center line. Any insight and help will be very appreciated! |
60-66 Nut
You will have to perform the steps necessary to calibrate your die, in your bender. When you do this, that will give you the info the software needs in order to give you the info to make exact bends in your tube. You need to do this because every bender and die set can vary. These steps hould be outlined in the owners manual for the software. If not, contact Bend Tech and they will be happy to help you with that info. You will have to have the serial number and some other info for your copy of the software handy to give them.
What brand of bender do you have?
I see, but I haven't installed the program yet and will read more on the prgram before I do. I picked up the Woodward bender and have made a few bends with it and it works well.
60-66 Nut
I think the Woodward Fab bender is the bender that Mittler Bros used to make.....maybe they still make it, but just for Woodward Fab.
SweetandLong68- Are you thinking of doing your own cage also and if so what's you plans for your truck?
Also sorry for turning your thread it to about me and I will post pics of my cage for you when I get more of it done. |
Your UncleBen
Its is a possibility.... Even if we don't do the cage ourselves I still wanna know what I want and need to be looking for. Looking to stay 8.50s and slower.
Thanks Chris
I found a couple pic's of my cage when it just got done. This cage got a NHRA sticker for 8.5 and slower last year.
1969 C10, 2005 LLY Duramax, Wagler Competition built motor, Bullseye Power triple Turbo's, Rossler th400, Neal Chance Racing Converter, Danville Performance tunning. 8.3@168mph 1700+ HP |
60-66 Nut
I'm surprised you got away without any cross bracing between those rear bars.
Always a work in progress
What are ya'll using for back glass with the bars going through it?
USMC Retired Never trust a man who can't laugh at his own fart! 2010 Silverado Crew Cab 73 SWB 5.3/4l80e Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=695168 |
#13 |
Pics of mine with a S&W main hoop with custom bending on rest of cage.
'72 SWB 3,600# Indigo Blue , Sunset Racing Pump Gas 582" 1,002hp / 833tq ,Transking 400 W/ Transbrake, Moser Dana 60 w/4.30 Old Motor: 60'. 1.43 1/8 6.58@104.64 1/4. 10.42@127.10 Nitrous: 60'. 1.28 1/8. 6.15@ 112.02 1/4. 9.75@ 136.32 |
#14 |
Main hoop
#15 |
More
#16 |
BUMP! I wanna see more!
Jeff 96 C3500 Crew Cab Long bed (Waiting on Cool Name) 64 C-10 shortie stepside, "Ole Brownie" C-10 Club My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345 |
#17 |
I just started on mine so no pics yet, only have the outriggers to tie the frame to the cage installed. I have been fixing the floor pans so that everything is rite before I started the cage work.
#18 |
Anyone get a cage done without using plastic rear windows cut for clearance?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#19 | |
It's Better With Nitro
You'd have to build it to the roadster spec to eliminate the rearward bars from a main hoop configured roll cage. Otherwise, if you use a traditional roll cage with main hoop, you'll have to run rearward bars and then will end up passing through the rear window or cab itself.
#20 |
There's a few u tube videos of trucks with cages I've been looking at. Like this one dudes fifties Chevy, he went out through the metal above the window but I don't know about in your truck.
Live and let live ![]() |
