Old 11-24-2013, 07:10 PM   #1
Jahloha
Jahloha's Avatar
Rebuild 600K Mile Engine OR Not
Team:
I just pulled the engine from Gramps' truck. The odometer reads 575K miles and my grandfather had the engine overhauled once since 1970.
Would you even consider getting an engine with this kind of miles, machined and rebuilding it?
All input and opinions would be appreciated.
Mahalo,
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-24-2013, 07:31 PM   #2
Terry Crist
Re: Rebuild 600K Mile Engine OR Not
No reason not to as long as there are no cracks anywhere and as long as it has not been bored too far.
Check the bore size and if it is not too far over (I would not go more than +.060, but that is just me) then have the block magnifluxed (sp).
Terry Crist is offline   Reply With Quote
Old 11-24-2013, 07:35 PM   #3
67_C-30
I have a radical idea!
67_C-30's Avatar
The speedo can't actually read 575,000 miles. Even if it could, there's no way a '70 model carbureted engine will go 575,000 without needing boring, unless it has been done before.
The last digit on the odometer represents tenths, not miles.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-24-2013, 07:39 PM   #4
zeldman
zeldman's Avatar
Depends....Off the top of my head... is the engine already apart? Was it bored over on the previous overhaul? My suggestion would be to take it to a reputable engine builder/machine shop and have them check the block for you, making sure the cylinders are round, not tapered or oval shaped, and check for cracks.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 11-24-2013, 07:49 PM   #5
Lee H
Lee H's Avatar
Only your machine can tell you for sure, anything else is a guess.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-24-2013, 08:02 PM   #6
bigmac73
bigmac73's Avatar
Agree with above, just have them Mic it out and check the block over they will let you know
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-24-2013, 08:12 PM   #7
Jahloha
Jahloha's Avatar
Thanks everyone. Thats what I thought.
-JASON
