11-24-2013, 08:42 PM | #1 |
My First C-10 (From Vancouver Canada)
Hi all,
I have just picked up my first C-10. Its a 72 longbox, with a 350. I'll let the pictures do the talking. Im going to use it as my daily driver, and as you can see, I need a new tailgate. If anyone knows the cheapest place to get a tailgate, I would appreciate it. Im after a smooth aftermarket one, not a stock one if possible. Ive looked on eBay, but those just seem like skins, not entire frames and skins. Anyway, thanks all, I look forward to getting involved in the community. Cheers, Ryan |
11-24-2013, 09:27 PM | #2 |
Re: My First C-10 (From Vancouver Canada)
Welcome from across the ditch!
Have you toured KMS yet? THey might find you one. http://www.kmscarparts.com/ |
11-24-2013, 10:35 PM | #3 | |
11-25-2013, 12:26 AM | #4 |
Cool! hopefully that is a primer-sealer on your truck. straight primer will absorb moisture and produce rust on any areas without good paint. epoxy better.
11-25-2013, 12:59 AM | #5 |
Yeah, I will either plasti dip the truck for the winter, or have it painted in a couple of months, so it shouldn't be too bad either way.
11-25-2013, 09:17 AM | #6 |
Very nice truck you have. ( by the pix of the area and the types of roofs on the houses I'd swear you were in california. it looks warmer there than here, 14 degrees)
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
11-26-2013, 02:11 AM | #7 |
Thanks. It definitely isnt warmer....well, you probably mean 14 deg f, so yeah, it was warmer. lol
11-26-2013, 07:53 AM | #8 |
just curious, whats the steel band running parellel along top of the radiator in the engine bay pix?
11-26-2013, 11:22 AM | #9 |
Mounting bracket for the e-fan. The po didn't want to push the mount pins through the rad fins it looks like, so he made up a mount bracket that uses the rad mounts
11-26-2013, 11:38 AM | #10 |
11-26-2013, 06:01 PM | #11 |
