Old 11-24-2013, 08:55 PM   #1
Spblack
Spblack's Avatar
inner fender wells on 59 apache with camaro clip
Does anyone have some pictures of what they did with their inner fender wells after they installed their Camaro clip? I am trying to decide the best route for trimming mine. thanks
Spblack is offline   Reply With Quote
Old 11-24-2013, 09:31 PM   #2
1958Warrior
1958Warrior's Avatar
Re: inner fender wells on 59 apache with camaro clip
I trimmed mine by following what ChuckDriver did see pic in post #161
http://67-72chevytrucks.com/vboard/s...=334552&page=7
I made measurements off of the top crease and the little finger looking crease , eyeballed it a few times drew it with soap stone , I didn't make the cut out as wide in the rear as he did and a little shorter , I think I went about 1-1/2" above the top crease ,cut it out using a HF body saw and 1 1/2 pak of their cheap corse blades.
I've got a few pics in the camera card of the my inners but you get the idea.
But you may need to trim more if your clip is welded to the bottom of the frame. Ours was blended into the frame.
1958Warrior is offline   Reply With Quote
