11-24-2013, 09:17 PM | #1 |
PO changed the steering column and moved the ignition to it
PO changed the steering column and moved the ignition to the column
and filled the hole were the switch was . The ignition is mid 80 /90 who knows but it has the inherit sloppy ignition that either locks and jams or can be turned with out a key I got the Door key which works , I want to put the switch back on the dash I don't have a problem re keying lock or replacing . Is there any place to get the whole bezel / switch new for the Dash ? or just start scrounging ? |
11-24-2013, 09:29 PM | #2 |
Re: PO changed the steering column and moved the ignition to it
I would contact one of the several vendors on the website and see what they have available
11-24-2013, 09:42 PM | #3 |
11-24-2013, 10:12 PM | #4 |
My truck came with a few parts from a donor 81-84 Chevy ?? I removed the tilt because of the locking steering wheel, Ign switch messing up, neutral safety not being hooked up, horn not working. I just installed a new tilt column from CPP. Now working on wiring back to the old switch. Good luck with yours
11-24-2013, 10:39 PM | #5 | |
I just saw CCP columns I think they make Floor shift columns from what I see so going to give them a call |
