Old 11-24-2013, 11:48 PM   #1
tr4boy
Need some help diagnosing my problem
folks,
I just rewired my 63 C10 with an american autowire kit. installed a new turn signal switch and upper bearing. the autowire kit is awesome and everything worked as planned. Been driving it for a couple months with no issues. I found a stock steering wheel and decided to replace the grant cheapy wheel that it came with. I got all the reproduction horn parts and proceeded to attempt the install this weekend. Didn't really go well. Not sure if the repro parts are not correct, but couldn't get it to the point where the horn button would have any movement. Eventually gave up and pulled out the horn contact.
Went to start the truck and no spark and the turn signals are now wonky. Right works okay but left runs both right and left. Neither work with the brake pedal under pressure. all fuses test good
Pulled the steering wheel again and pulled out the turn signal switch. No pinched wires or other signs of damage. the only new things are the turn signal cancel cam and a botched horn install.
Checked power to the HEI distributor - shows 12 volts but ranges all over the place with ignition on. still no spark though.
Pretty frustrated...any ideas?
tr4boy is offline   Reply With Quote
Old 11-25-2013, 10:53 PM   #2
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: Need some help diagnosing my problem
You may have shorted out the horn relay. The horn relay send power to different places on these trucks. I would go check mine, but the wiring has been altered for a long time. Someone here has a diagram I'm sure. I haven't been on here much lately. As far as the turn signals go, check the signal switch itself. They have some little fingers in there that send power to the different lights. If they get bent just a little, they can act weird. I had one that would light up the front driver side turn signal when I hit the brake pedal. I hope this helps---Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 11-26-2013, 12:52 AM   #3
ChevyYoung
I replaced my turn switch. Auto wire also, the new one came with hazard switch capabilities. So I took apart the new one and the old one The pins inside are set up differently. I bent the pins inside the new switch to match the old ones it worked fine afterward. You may also be able to just switch the pins. Basically a contact issue when turning the switch to left or right . Hope this helps make sure everything is grounded good
ChevyYoung is offline   Reply With Quote
Old 11-26-2013, 12:52 AM   #4
tr4boy
thanks, I'll take a look at the relay…
Old 11-26-2013, 07:49 AM   #5
PGSigns
PGSigns's Avatar
Look at your wiring diagram that came with the AAW kit. It should tell you what is up in the column. Should not be related to the no start issue. To do a quick test run a jumper wire from the battery to the hot side of your hei. Spin the motor over with the key and it should light. If not you may have a hei issue. Nothing in the column is tied to the start run on these trucks.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-26-2013, 07:54 AM   #6
ChevyYoung
Your right PGSigns I didn't read that part about the no start.
