Old 11-25-2013, 12:42 AM   #1
lowbb72
71-72 drop spindles, rotors, ball joints, suspension, all new!!
I have decided to go a different direction on my build so up so sale I have the following
1. 2 1/2" mcghautys drop spindles sold!!
2. Ssbc 12" rotors drilled and slotted 1.25" wide will all new timkin bearings, nut, washer, cap, and seal. $280 new
3. Moog pitman arm, idler arm, inner and outer tie rod ends, and sleeves sold!
4. Upper and lower a arm cross shafts sold!
5. Upper and lower 71-72 ball joints sold!
6. 67-68 center link $30
7. Cpp upper shock mounts. Sold
8 factory upper control arms sand blasted and ready to paint $60
9. Lower control arms cupped for bags. Sold
10. Factory swaybar with new bushing kit. $100
11. Rear trailing arms sand blasted and includes new poly bushings. $150
12. factory trailing arm crossmember $80
13. 2 inch fabricated blocks and u bolts. Sold
14. Power Steering gearbox (factory) feels pretty tight $60
15. Factory 2wd front crossmember sandblasted $100
All priced plus shipping. May not ship larger items
lowbb72 is offline   Reply With Quote
