Newb doing a LS3/6L80 twin turbo swap K5
Been a lurker here for a while now,thought some of you may be interested in my latest project swap:1970 K5 blazer 4x4 that I picked up earlier this year.I bought the truck out of Baja Ca. original paint zero rust couldn't pass it up so last Friday I pulled the carb'd 383 and TH350 trans out and started my swap here are the plans:
I have a L92/LS3 that I got from a friend for a song and dance,and a donated 6L80E out of a 2007 Escalade.Decided that wasn't enough so I also scrounged together a set of used Grand National turbos that I will be running as well. It will be kept 4x4 using a NV241 T-case with a pass front diff drop,I have also ordered the Dirty Dingo complete front replacement cross member and mount kit for the swap,should be here today. I was able to get the aluminum radiator Precision turbo a/a inter cooler and the dual 4th gen fans mounted as an assembly this past Saturday and my intentions are to have the motor in and turbo fab started by the beginning of the weekend.Here are the pics so far: ![]() ![]() ![]() ![]() |
![]() Join Date: May 2006
Re: Newb doing a LS3/6L80 twin turbo swap K5
Sounds very interesting....ill watch! cool to see its staying a 4X4
Nice first post
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
Cool...will be watching your progress!
'72 C to K20 "Cannibalizer" http://67-72chevytrucks.com/vboard/s...32#post8653432 '85 K30 "Big Nassy" [B]'85 C10 [B] "Corpse" '01 2500 Suburban ...party wagon & tow truck '06 Silverado SS...DD '06 C1500 WT...DD '07 Classic C1500 WT...DD Built & sold cause can't keep 'em all: '72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190 '55 Chevy straight axle gasser https://www.trifive.com/forums/showthread.php?t=173938 '69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541 '86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619 |
I'm in for coolness factor alone.
Happy to be here
![]() Join Date: Mar 2000
Following....
![]() Join Date: Apr 2005
LS3/6L80 and forced induction hhhmmmmm sounds like something I wold do....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
made some progress,motor and trans are in,working out the Escalade T-case to be clocked differently for the pass front diff in the blazer.Looks like I can rotate it to be 180 degrees off from factory,Ill have to plug the vent tube,make a new pick-up for the internal pump then drill and tap for a new vent tube and weld a bung on it for the proper fill hole height and level,But it will be bad dog full time AWD!Should have the harness by the end of the week,fuel system is coming together using a 1991 Bronco II tank,fits perfectly btw.By the end of the coming weekend it should be nearly ready to run and turbo fab will begin.I have a few pics that I took I will upload later today
Re: Newb doing a LS3/6L80 twin turbo swap K5 MORE PICS!!
Made some progress..turns out the Escalade T-case doesnt have an internal pump in it,so I was able to just plug the existing vent tube and make a new fill/drain plug location and a new vent.The adapter took slight modification with a die grinder to orient the T-case where I wanted it,no big deal,bolted right up and worked perfectly
![]() ![]() here are some pics so far: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by danimal95; 12-05-2013 at 10:28 AM. Reason: title change |
Bad a@#! Already thinking about 1/4 mile times!
Side note: Imagin this truck awd/4x4 with slicks on all four corners
68 C10 SWB W/ 72 FRONT CLIP 343SB TH400 64 C10 SWB 406SB TH400 74 SUBURBAN 454BB TH400 78 K10 SWB 350 TH350 6" ON 35" BFG MUD 71 K5 350 W/ TBI 700R4 6" ON 38" BFG MUD 00 K3500 DRW BIG BLOCK "DRINKING PRBLM" |
Sweet!!!
~ It's a Learning Process ~ Click Here for my Blazer Build: 1971 Blazer 4x4 Click Here for my Work Truck Build: 1970 C10 LWB Toys: 1970 C10, 1971 Blazer 4x4, 1976 Corvette Stingray L82, 2011 Cadillac CTS 6 speed, 2008 VTX 1800F |
here is what she looks like and that will not change,I love the patina on the truck,very original looking
#13 | |
#14 |
Simply Amazing.
1961 C1 Corvette 1959 El Camino 350 TPI, 9" 4 w disc 69 Blazer K5 - sold July '20 2021 Durango RT 5.7 |
#15 |
#16 |
great build... giving me bad ideas =)
if you are making it all wheel drive, how are you dealing with the front differential so its drivable around town... im not sure if the front wheels have lockers to engage as well... thanks
Ed will be known as the Tiger Woods of the integration business |
#17 |
#18 |
the front diff is an open style carrier and the t-case uses a viscous coupler and a planetary set so it doesnt have a solid or direct coupler between the front and rear drive wheels,it allows for slip and it is split 40/60 front/rear.It will drive like an 07 awd escalade,not like an antique 4x4 where the wheels are locked together front and rear when the 4x4 is engaged
#19 |
![]() Join Date: Jul 2012
it is going to be a WILD ride!!
#20 |
wonder lake huh? your just down the road from me maybe 20 mins- half hour, might have to meet up someday and check this bad boy out. i like the use of the 6l80, little bit different than the commons th350/700r4/4l80 trans everyone uses, and the use of the escalade t-case is awesome as well, most guys are swapping these into 2wd trucks, which is laaaaame!! haha i have no room to talk, my truck is 2wd... but anyways, sweet build. what is your final hp goal? subscribed btw
#21 | |
#22 | |
#23 |
![]() Join Date: Apr 2006
How are you adapting the control for the transfer case? I would imagine it is electric rather than a stick like the 205.
Kirk 72 Blazer CST 4wd highlander |
#24 |
#25 |
That is cool, I want to do the LS conversion in the future and figured I would adapt a 4l60 or 80 and just use adapt my np205. This seems like a viable alternative especially if it is full time AWD. Did you consider moving the engine forward at all instead of moving the trans cross member? I know others move the engine forward to adapt the 700r4 but I would imagine the 6l80 is much longer.
