11-25-2013, 04:48 PM | #1 |
WTB: Correct th400 kickdown switch for 70 bb
I have a 70 cst big block 1/2 ton truck that is missing the carb mount kickdown switch for the th400. My question is did all 70 big block use a unique 4 barrel connector switch on the carb that had spark arrest. Are did some 70 have no spark arrest and use the more common carb mount 2 spade connectors. Can multiple people with 70 big blocks see what is original for me. Spark arrest type or non spark arrest carb mount switches. Thanks people.
11-25-2013, 09:35 PM | #2 |
Re: Correct th400 kickdown switch for 70 bb
The one on my 70 is the four pin type
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-25-2013, 09:41 PM | #3 |
Ok 71 super then I assuming it has the spark arrest. So what is extra in hardware that the spark arrest system consist of in 70 model ?
11-26-2013, 12:21 AM | #4 |
That is a great question I will have to dig into a find out.
11-26-2013, 12:29 AM | #5 |
71 super would you have an extra 4 barrel pin switch and mounting bracket to sale me, please.
11-26-2013, 12:53 PM | #6 |
I have an extra bracket that is correct for 70 model bb but no extra switch.
11-26-2013, 01:15 PM | #7 |
That is a start. Can you post a picture of your bracket and how much shipped to Amarillo Tx 79106. Thanks
11-27-2013, 04:20 PM | #8 |
Here is picture of the bracket. $30 shipped. You might contact 70cst first I "think " he had a complete set left over from his build. If not I will be happy to sell the bracket to you. Harold
11-27-2013, 06:52 PM | #9 |
Ok thanks for the heads up I will check with him 1st and let you know. So did all 1/2 ton 70's come with tcs (spark arrest) and this 70 only kickdown switch? Anbody, know for sure?
11-27-2013, 08:08 PM | #10 |
The tcs is not in place on my truck, and no sign of the relays ever being on firewall, the switch is for sure a 70 only switch and is different from the two blade type typically found on earlier th400 transmissions
12-18-2013, 12:51 AM | #11 |
Still in need of the 70 only kickdown switch, full package if possible, carb switch ( 4 barrel connector), wiring harness, and mounting bracket. Anyone?
12-18-2013, 12:53 AM | #12 |
ttt
12-22-2013, 07:05 PM | #13 |
Re: WTB: Correct th400 kickdown switch for 70 bb
ttt
12-23-2013, 12:39 AM | #14 |
Hey kaphillips ...
I have not forgotten you. All my misc. truck parts are back in Zanesville which is about a three hour drive for me. It will likely be spring until I get into those parts. I thought I might have brought some parts with me but no luck. Thought I would let you know.
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-23-2013, 12:48 AM | #15 |
Thanks 70cst for the update. I am a patient man and in no hurry. Let me know in the spring, have a merry Christmas.
12-31-2013, 10:47 AM | #16 |
My 70 CST has a 4 spade kickdown switch, but only 2 of the spades are used. I thought all the turbo 400 kickdow switchs were the the same for 1970. Only the harness was different. One with TCS and one without. The 4 spade plug was used on both harnesses.
Roger Koop |
01-27-2014, 05:21 PM | #17 |
Still looking for complete package, switch, harness, and wiring harness? Anyone
01-30-2014, 02:09 PM | #18 |
I have a new harness, but will need to check on switch and bracket.
Roger Koop |
01-30-2014, 02:21 PM | #19 |
Thanks Roger please check if you do have the complete package. I you do save it for me and we will add it to my tab and parts list and will settle up when the 4-way vacuum manifold port comes in. Thanks
05-22-2014, 08:53 PM | #20 |
Still looking . Ttt
