11-25-2013, 07:46 PM | #1 |
86 c-10 LS swAp
I have a 86 short bed c10 Chevy still has 305 700r4 tranny. I plan on doin a 5.3 with the victor jr Intake and carb setup. I've
It's already got a rebuilt 700r4 in it since I'm goin carburated would it be better just to keep that 700 r4 n it. And what adapter will I need to marry the motor to the tranny will I need a diff flywheel is there a kit? |
11-25-2013, 10:47 PM | #2 |
BAD BOW-Silverado XST
Re: 86 c-10 LS swAp
Welcome to the site. Read these articles on using a carb setup.
http://www.aera.org/ep/downloads/ep1...2010_10-19.pdf http://www.superchevy.com/technical/...sc_conversion/ The 700R4 bolts right up. You do have to bolt on a correct flexplate. Read this: http://www.superchevy.com/technical/...ine_swap_tips/ Take plenty of pictures!! I would like to see the conversion and carb setup. I've thought of using an LS carb motor on a future project. |
11-25-2013, 10:50 PM | #3 |
Re: 86 c-10 LS swAp
Thanks man I'm just now starting the conversion I hope to have it done by January feb
11-26-2013, 10:33 AM | #4 |
Re: 86 c-10 LS swAp
Are you upgrading the cam? You can easily gain power by swapping cams. The stock cam will make a nice daily driver.
