11-25-2013, 10:22 PM | #1 |
hp estrimate again.
saw a similar thread and was womndering the same thing on my setup. about what horsepower can i expect? the machine shop didnt give me a real soild answer all they said was "it is easy to make one horsepower per cid" so i didnt know how to take this
i have a fresh rebuilt 350 forged 10:1 pistons bored .040 crane cams z-274 ( i can get specs later) the heads were rebuilt, valves, guides, new seats, the whole nine yards (not sure what heads they are, i know their not double humps or anything like that just some basic 350 heads) edelbrock performer intake holley 650 with vacuum secondaries hei distibutor full length headers thats about it for power adders if someone could give me a rough estimate thatd be great! this engine is mated to a 700r4 with 2000 stall converter and 4:11 gears |
11-25-2013, 10:31 PM | #2 |
1972 K20
Re: hp estrimate again.
How do you know the engine has 10:1 if you don't know anything about the heads? The two most important parts are the heads and cam. Since you have no info on them it would be nothing but a guess at best. The heads, Head gasket and deck height determine your static compression ratio.
11-25-2013, 10:35 PM | #3 |
1972 K20
Fat fingers on a small phone! Also the piston shape and number of valve reliefs are part of your compression calculation!
11-25-2013, 10:35 PM | #4 | |
11-25-2013, 10:36 PM | #5 |
they said the heads were 1978 model year with the hardened seats if that helps any
11-25-2013, 10:55 PM | #6 |
1972 K20
We'll I looked up the cam specs. Your TC stall might be a bit tight and if you have power brakes you might have a firm pedal if you can keep it idling in gear. Did you put matched valve spring in your heads? Because your heads are going to limit peak power. I think you may have a 375 hp motor. We're you thinking more?
11-25-2013, 11:12 PM | #7 | |
11-25-2013, 11:19 PM | #8 |
1972 K20
You put about the biggest cam it you could get away with! Premium gas at 12 mpg can get expensive for a day driver! Anyway have fun with it.
11-25-2013, 11:36 PM | #9 |
Haha yeah thats about right. Theres a reason i put the 700r4 in it lol. But hey cams arent to expensive, if i dont like it ill stick a smaller one in. Thanks for your help man! Greatly appreciated
11-25-2013, 11:05 PM | #10 |
That cam is fairly stiff for a DD truck. NOT radical by any means just on the upper end of a DD working truck (2200-6400). Those heads are killing the power potential of this engine. Maybe 325hp on a nice cold day. A set of DoubleHumps that are port matched would really wake this thing up.
With 76cc heads your actual CR is likely closer to 9:1.
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
11-26-2013, 11:09 AM | #11 | |
11-26-2013, 12:03 PM | #12 | |
11-27-2013, 12:42 PM | #13 |
The only way I know how to get accurate compression ratio is to cc the chambers and calculate the piston to deck height as well as add in your bore. Other factors can come into play here though. No need to do a long write up on that since your doing a pretty basic rebuild. Summit racing has a compression calculator that is pretty handy. You need to know what the specs are first though.
11-25-2013, 11:06 PM | #14 | |
It has happened that some people put 305 heads on a 350 to get better compression, but the valves are shrouded by the small combustion chamber which reduces flow around the valves.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
11-26-2013, 12:37 PM | #15 | ||
"I ain't nobody, dork."
Stay away from the airgap for a DD rig.
A plain old performer RPM would be the best bet. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
11-26-2013, 11:04 PM | #16 |
The regular Performer will be fine, but it will need to be Port-Matched to the heads.
Being in WI. you will need the warmth of a regular style intake verses the "Air-Gap" type.
11-27-2013, 12:41 AM | #17 |
I have a radical idea!
With '78 model unported heads (probably 882's or 624's), there's no way that engine is anywhere near 375. With flattop pistons, and 76cc heads (that's what '78 model heads would have been) the engine is probably around 9 : 1 or a little under. Your pistons would be 10 : 1 with 64cc heads. To acheive 10:1 with 76cc heads, you need a .125" domes.
I'd estimate the engine in the 300-ish range, maybe a touch more. What you have is basically a stock engine with a cam. You have to consider that pre-1972 (pre net HP ratings) 9 : 1 CR 350 4bbl made between 260 - 270 HP. Depending on which heads you actually, they will either be comparable or flow less than earlier heads. A performer intake is equivalent to a non smog 4bbl intake in terms of airflow, and your 650 Holley with vac secondaries gives up a little power compared to a new tuned 750 Q jet. Taking that into consideration, your cam and headers are really the only power adders. A camshaft and headers alone can not gain 100HP over what is basically a stock engine.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-27-2013, 12:42 AM | #18 |
BTW, I don't mean to sound harsh, I'm just giving you the reasoning behind the estimate.
11-27-2013, 01:12 AM | #19 |
I agree with 67_C-30. Probably around 300. The cam doesn't match the rest of the engine. Late 70s cylinder heads were usually light duty and not suitable for high performance engines.
By the way, a Performer RPM almost matches the cam, but I'd keep the Performer and switch cams instead. It will take more work to build a high rpm engine, and won't be that great in such a heavy vehicle. You want torque, and lots of it! |
12-03-2013, 03:29 PM | #20 |
no offense taken! id rather have someone tell me the way it is then blow smoke up my, well you know what I mean. do you think I was taken for a ride by the machine shop and lied to when I was told 10:1 and 350hp? really disapointed
11-27-2013, 01:05 AM | #21 | |
Here's a great article dyno testing the 350 HP L79 327 and L46 350 engines. http://www.superchevy.com/technical/..._dyno_testing/ The "Its easy to get 1 HP per cid" thing gets thrown around a lot these days, but it takes more than most people thinks it does with 30+ year old stock small valve heads. Its much easier with ported or modern heads. Its even easier with LSX engines, again, mainly because of the airflow of the heads.
11-27-2013, 12:34 PM | #22 | |
2006 Z06 2013 Cruze |
12-02-2013, 03:36 PM | #23 |
thanks for your help guys, i will look further into what heads i have. is there a way to decode the heads (serial number or something?) or any identifying marks to know what i have. the motor is assembled (heads on, intake on, carb on, painted) so id rather not take the heads off if i absoleutely dont need to
12-02-2013, 07:07 PM | #24 | |
12-02-2013, 08:33 PM | #25 | |
