Old 11-26-2013, 02:16 AM   #1
tattooboy37
Speedometer not working odometer working
63 C20 3 speed manual transmission w/ column shift.
I haven't been able to figure out whats going on since the odometer works while driving but not the speedometer needle. Then when I pull out the cable from the tranny and spin the cable end it moves the speedometer needle.
Why one but not the other since both connections seem good.
Shouldn't the odometer not work if the gears inside the tranny weren't spinning the cable to move both it and the speedometer. I could see it being inside the tranny since I can get the needle to move by hand, but since the odometer works while hooked up that doesn't make sense. Plus I could see it being on the dash side if the needle didn't move while unplugged from tranny, but since it works that doesn't make sense either.
Please its been driving me bonkers.
tattooboy37 is offline   Reply With Quote
Old 11-26-2013, 07:32 AM   #2
64tantruck
64tantruck's Avatar
Re: Speedometer not working odometer working
I too have a similar situation on my 64 C20 my speedo works but my odometer is stuck at 62000. tenths advance but stays at 62,000 when it gets to 62,000.9 it rolls to 62,000.0 just happen last month.
Sounds to me like you have a broken gear. Not sure of the inter workings.
glenn
Glenn Korec
Jamesville NY
64 C20 350ci Turbo 350 tranny 3.73 gear with air ride.
61 Apache10 (wife's truck) 327ci powerglide.
http://67-72chevytrucks.com/vboard/s...d.php?t=570100
64tantruck is offline   Reply With Quote
Old 11-26-2013, 12:44 PM   #3
tattooboy37
From what I've read it just sounds like you need to remove the number cluster and lube it up. something is causing the next number to bind up.
I just cant figure why my speedo works by hand but not when hooked up to tranny. from what I have read both are turned by the same plastic gear in tranny.
Old 11-26-2013, 01:03 PM   #4
A.T. RockDriller
A.T. RockDriller's Avatar
Very puzzling.
I think if it was me, I'd remove the cable end from the tranny again and grind about 1/16" of length (max) off the inner cable.
Safe experiment..... and also may relieve possible binding.
Good luck.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 11-26-2013, 08:21 PM   #5
tattooboy37
I'll give that a try, cant make things worse since I don't care if odometer works. I can always order up new cable and new gear mechanism if necessary. just trying to trouble shoot things and find out whats up.
Old 11-26-2013, 09:11 PM   #6
Dillon Rock
I have a similar issue. When I bout the truck, the odometer and the speedometer weren't working but the needle was flicking, it smoothed out and worked again, then I went on deployment, came back, did it again and last night it decided to start working again. A guy I know at my local Car Quest says the cable shrinks over time and could be the culprit to our issues.
That's the thing about a Chevrolet, no matter how they look, whether it be a trailer queen or a good ol' used farm truck, no other truck on the road will always look that damn good wearing a Bowtie.
Dillon Rock is offline   Reply With Quote
