Old 11-26-2013, 11:01 AM   #1
Mgicm
water pump /pulley bolt??
HI
Trying to find some bolts that go into the lower pulley on my 76 chevy motor and cant find them anywhere local. I have two bolts but of course need 4. Here is a pic. anyone know where I could grab them locally or is it a hunt in a junkyard. Would like to know the size so i have it for reference. Sure appreciate the help.
Mgicm is offline   Reply With Quote
Old 11-26-2013, 11:34 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: water pump /pulley bolt??
Your question isn't clear. In the title you mention water pump but in the question you mention "lower pulley"
The water pump pulley uses 5/16 bolts while the crank pulley uses 3/8 bolts. Which one are you looking for ?
Old 11-26-2013, 11:40 AM   #3
Mgicm
its the bolt that goes into the pulley. sorry for confusion. It used to have a fan on it but i removed for a different setup so now I need to find shorter bolts as pictured. The threads on these and the end are such that I cant find any available in auto stores.
thanks
Old 11-26-2013, 12:26 PM   #4
Tx Firefighter
That's a normal 5/16 fine thread bolt.
Look at hardware stores for 5/16-24 by however long you need. Its a very common bolt.
Old 11-26-2013, 12:28 PM   #5
xrcr
Go to a hardware store, take your old bolt to match thread and get a 5/16 grade 5 whatever length
xrcr is offline   Reply With Quote
Old 11-26-2013, 12:33 PM   #6
Mgicm
hmm ive tried that. seems the end is tapered while the ones from the stores are not with threads to the end. So when it goes through the pulley I believe it is an issue. Its been a bit since I tried finding the bolt but i know the ones from ace and tractor supply didnt thread in at all. Didnt want to force it.
Old 11-26-2013, 12:55 PM   #7
Tx Firefighter
You need to run a tap through the water pump holes then. An off the shelf 5/16 UNF bolt should screw right in place.
Old 11-26-2013, 02:26 PM   #8
77 ChevySport
Originally Posted by Mgicm View Post
HI
I bet your local Chevy Dealer will have them. Those a very common with
all Chevy Engines. If no luck any of the Corvette/Camaro catalogs will
have tons of them. Larry
P.S. Should be easy find at any auto junkyard.
77 ChevySport is offline   Reply With Quote
Old 11-26-2013, 02:59 PM   #9
Mgicm
i got it at a hardware store 5/16 24 fine thread thanks!
