Old 11-26-2013, 07:19 PM   #1
revitout
Wiper Travel Issue- Adjustment?
Hi there i'm from New Zealand and just got me a 76 suburban chassis lenghtened 500mm with a 84 crew cab and short box, 400sb t400. Real good conditon. I have issue with wiper over traveling ,as in i runs over the screen edge on the drivers side. In the down position it is low as it can go. Is there any travel adjustment on the linkage?Are there different wiper arms for each side?- these look the same.It looks as though its been going on for a while as the window rubber has a wear groove. Cheers
revitout is offline   Reply With Quote
Old 11-27-2013, 08:45 AM   #2
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: Wiper Travel Issue- Adjustment?
I would remove the wiper arm, and rotate towards the cowl and reinstall.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-27-2013, 01:54 PM   #3
revitout
Thats the problem its already hard against the window edge. Its like the arc travel distance needs to be reduced.
Old 11-27-2013, 02:57 PM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Welcome to the site. I think the set point when down, is the wiper being parallel to the dash. That's how I have mine. They actually sit up high.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 11-27-2013, 03:11 PM   #5
revitout
Hi Thanks, when i work out how to post pictures i'll put some up. Keep getting upload failed errors. The wiper blade is parallel to the dash and that is when it is right down against the window rubber. In the up postion it travels past the side window rubber. Do you know if the wiper arms are different on each side , mine are the same. No matter what i could do to the arm (mechanicaly) it wont change the fact that the arc travel is too much.
Old 11-27-2013, 03:36 PM   #6
bnoon
For your pictures, if you're attaching them directly to this forum, try resizing them as your pictures may be too large for attachment limits on this site. If that's something that's too technical, let us know which program you're using and we can help you resize them. You can also load them to a picture hosting site and link to them from here.
As for the wipers, there aren't any travel adjustments I've ever seen on these trucks. Since you Suburban chassis has a custom length and different body on it, I would suspect some of these other parts aren't stock either...
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
