Old 11-26-2013, 08:56 PM   #1
AzCountryman
AzCountryman's Avatar
direct fit bench seats
What year trucks can you pull a donor bench seat from that will be a direct fit for 1966 c10?
looked at an 1984 chevy but that one wont work.
Are you a collector? If so come check out Collectorsunleashed.com Doesnt matter what it is we have a spot to show it off.
http://www.collectorsunleashed.com/#
AzCountryman is offline   Reply With Quote
Old 11-26-2013, 09:32 PM   #2
FlowerForwarder
Re: direct fit bench seats
I believe a GM seat from 88 -94.
Most pull a part yard are about $20ish
FlowerForwarder is offline   Reply With Quote
Old 11-26-2013, 09:35 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Or another 66 c-10 seat. lol.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-26-2013, 10:24 PM   #4
NEWFISHER
NEWFISHER's Avatar
The 88 to 94 seats fit well side to side, can be run with the stock tank location, are a thinner construction to build from to get more room between you and the wheel and the front holes of the slider assemblies are a direct bolt in. Just have to drill the rears and through bolt with a body washer or weld in a captured nut.
NEWFISHER is offline   Reply With Quote
Old 11-26-2013, 10:50 PM   #5
AcampoDave
AcampoDave's Avatar
My friend gave me the seat from his 69-72 Suburban and it fit the stock holes. I suppose the pickup to be the same.
AcampoDave is offline   Reply With Quote
Old 11-27-2013, 12:26 AM   #6
gixxer711
Hmm. I might have to see if I can bum a seat from someone with a 67-72 truck to test fit. It seems I read somewhere that you could unbolt the mounts from a 60-66 seat and bolt them to a 67-72 seat to make it a bolt in but never heard they bolted in directly.
Danny
64 C10 SWB fleet
gixxer711 is offline   Reply With Quote
Old 11-27-2013, 01:16 AM   #7
64-454ss
64-454ss's Avatar
Got a bench seat from my buddies 69 GMC to put in my 64 and bolted right in with 69 brackets. Easy swap!!
64-454ss is offline   Reply With Quote
Old 11-27-2013, 03:05 AM   #8
AzCountryman
So a 60-72...will bolt right in..maybe have to swap the brackets and an 88-94 but will have to drill new back holes.
Should be easy enough then to find a pre 72 seat
Old 11-27-2013, 03:31 AM   #9
BigDan3131
BigDan3131's Avatar
Why do you need to swap it? Do you not have one right now? I'm going to just have mine rebuilt and add the seat heaters they sell from LMC to both sides for the extra comfort.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 11-27-2013, 01:20 PM   #10
AzCountryman
The passenger side back support is broken. Needs to be rewelded. Plus it will need new foam and all that. I haven't priced getting a seat redone but seems like something that is expensive.
Old 11-27-2013, 03:47 PM   #11
OhioTT
I'm looking at '99-'04 silverado seats because they have built-in three point belts. Does anyone know if they will work with stock gas tank? I'm running a seat out of a Ford conversion pickup now and the center arm rest won't fold down with the stock tank.
OhioTT is offline   Reply With Quote
Old 11-27-2013, 03:49 PM   #12
LVPhotos
LVPhotos's Avatar
I had my seat redone in white vinyl black pipeing had broken springs for $300. Of course leather is more. You would probably need to recover replacement seats anyways.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
