Old 11-26-2013, 09:24 PM   #1
Sodell
Sodell's Avatar
A/C heater dash pad vents
Anyone have a good solution for the loose vents on the dash pad,(the vents wont stay in place and must point down? I am) going to do some work on the dash and want to fix the problem while I have it apart. Any one has any ideas that have worked?
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-26-2013, 09:43 PM   #2
4x4k30
4x4k30's Avatar
Re: A/C heater dash pad vents
i have allways just used a old folded up napkins... but yea i would like to see other ideals they are a pia.. its kinda like the vent windows too they are noisy i useally use silicone to seal them up or use a quarter to tighten up the vent handle
4x4k30 if trouble was money i would have plenty
4x4k30 is offline   Reply With Quote
Old 11-26-2013, 10:45 PM   #3
Sodell
Sodell's Avatar
Yea I would like to find a more permanent fix if possible, instead of springing for new ones.
Scott
Old 11-26-2013, 11:05 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
not sure if a heat gun would work?
i've heated some dash plastics to prevent "brittle" splits
slight pressure hold tab out ,till softened
or maybe heat from soldering gun,not sure if a lighter would be enough
let cool and check?
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-26-2013, 11:13 PM   #5
kelsfine69
18 Till I Die
kelsfine69's Avatar
There is actually a little pad of sticky foam that adds pressure to the sides I believe. I did my 87 camaro with a bit of sticky foam weatherstripping trimmed down. Works very well. Next time I pull my dash pad I will do these as well.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 11-26-2013, 11:26 PM   #6
83GMCK2500
I thought it was more of a sticky-backed felt or dense fabric that was on them originally. If you've got it apart, now is a perfect time to experiment with different materials.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-27-2013, 12:03 AM   #7
Sodell
Sodell's Avatar
Great idea.
Scott
Old 11-27-2013, 01:52 PM   #8
Rich84
Rich84's Avatar
I used the fuzzy side of a piece of black velcro..Creates just the right amount of friction to keep them right where you want them...
Rich84 is offline   Reply With Quote
Old 11-27-2013, 08:01 PM   #9
Sodell
Sodell's Avatar
I think I will try that first^^^ Thanks
Scott
